85 3.2 O2 sensor readings
Hi all, SmileWavy been a while since i have been here but glad to be back. Been a bad boy and have not spent much time with the old girl and have recently decided it was time to give her the attention she deserves. :)
Thought I would start by checking some basics on her starting with the O2 sensor and see if she might need a new one after sitting for so long. I performed the test and she was reading between 0.2v to 0.8v and occasionally swinging up to 0.9v. She was fully warmed up and all readings were at idle, done with a Digi MM. Any thoughts, normal with in range, good, bad, get a new one? Thanks in advance!!!! P.S. LOVE the spell check!! |
That looks ok to me I have the same readings on mine or similar, with an old simpson meter you can watch it dither.
Thanks 911obgyn, appreciate the reply
| All times are GMT -8. The time now is 04:13 PM. |
