Odometer calibration
I am in the process of doing the odometer repair and my question is do I need to be concerned about calibration. I don't see much if any talk about calibration. This on a '76 911.
Thanks |
I guess you could find a measured mile on the highway.
Non stock tire size can screw things up. |
Use a GPS unit, set your trip reading to zero and your trip odometer to zero, drive about ten miles or so and compare GPS reading to trip odometer reading. VOILA, you have your answer. These speedos and
odometers are notoriously not very accurate. I checked mine and it was not real accurate. Can't remember if it read higher or lower, but it was a good bit off. |
Does everyone who DIY have to do this or is there a way of taking it apart so that it is not out of calibration?
GPS is very accurate. |
The odometer is moved by a stepper motor that is pulsed by the magnet array on the ring gear which is picked up by the xaxle sensor and sent to the speedo/odometer. Some early electronic speedos had a pot to adjust indicated needle speed, but those who adjusted to correct speedo error found it did nothing to change odometer calibration. |
Glad to see you got to dive into this. How did this work out?
Mine was electronic so it was different than yours. I would imagine that the needle position and stepper motor can throw off calibration. I have a mental block of KPH to MPH conversion while driving so I use the Garmin set on the data screen for my speed. But I was fortunate to to be showing maybe 2 KPH faster than actual speed. I just glance at it and see what RPMs I am at in what gear and drive by the RPMs. Were you able to figure it out? Terry |
Here is a pic. of mine and on first look maybe I don't need to remove tne needle - what do you think? I don't know how to remove the brass fitting but then again maybe I don't need to remove it, perhaps you would know what is the bad part and how to get it apart? http://forums.pelicanparts.com/uploa...1532209053.jpg http://forums.pelicanparts.com/uploa...1532209073.jpg http://forums.pelicanparts.com/uploa...1532209087.jpg |
With a GPS in hand, get the car up to 60 MPH on the Speedometer, record the actual speed that your GPS is showing;, send the Speedometer to N Hollywood Speedo and gives them the GPS reading @ your Speedo reading of 60 MPH and ask them to re-calibrate your Speedo.
| All times are GMT -8. The time now is 04:10 PM. |
