911 SC Cylinder leak down test questions
At 110,033 miles in March of 2016, my mechanic performed a cylinder leak down test on my 78, 911SC.
The results were: #1=6% #2=7% #3=6% #4=9%R #5=6% #6 = 6% I'll assume these numbers indicate the engine is likely okay for another 20K-30K miles or more without a top end rebuild? What does the R after #4=9% mean? Have added 3 K miles in 2 years and all seems good. Looking for advice on how this information might support the sale of the car. |
Well
Leak down tests must be done correctly on Porsche engines and I find a big variation on the numbers. One mechanic tried to tell me my engine needed a top end and it had 8,000 miles on a rebuild. I latter told him that is was just rebuilt ...but he tried to say it was leaking from a bad piston ring in 2 cylinders...I tested it and got good numbers The car runs great, go figure, I am told the % of the leak down per cylinder should all be close together and yours seem to be wearing the same... |
A leak down test can be an indication of where a problem is, if one is suspected.
I am guessing that the R might mean rings. The mechanic should indicate where the leakage was occurring, if the number was high. If the motor is not using oil or fouling plugs I would not worry too much. A leakdown will not show worn valve guides. Have it done again by another mechanic after a while and see how it compares if you are concerned. If a compression test was done and one cylinder was low, a leakdown could indicate where the problem lies. IE, rings or valves. FWIW, I did a leakdown on a motor I just sold. I got 6-7% on all but #5 which was about 10% with leakage through the intake valve. Later the buyer did his own test and he was getting 2-4 % on all cylinders except #2 which was 12% through the exhaust valve. I pulled the valve cover and banged on the rocker arm and it went up to 6%. Probably both issues due to carbon flakes on the valves. If I was you, I would wait until you are selling and have the buyer do a test if he wants. |
| All times are GMT -8. The time now is 06:08 PM. |
