Puff of smoke on startup
Hi my car engine has puff of smoke on startup once ina while and typically after sitting for more than a day.
It doesn’t do it always and I don’t know what is the pattern.
Any thoughts?
Is this bad?
I’ve read somewhere that there is a valve that can be installed at the engine oil hose as some oil goes back in the crank from the oil tank.
Mthank you
1974 911 coupe 4 speed
Old 07-02-2018, 05:59 PM
They did it when they were new.
206 637 4071
Old 07-02-2018, 06:02 PM
Vintage Owner
Jack Stands's Avatar
One of mine could be fogging for mosquitos if it’s been sitting for a few weeks. But once it clears, it runs great and doesn’t burn excessive oil. It’s funny as my other cars aren’t as Smokey.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 07-02-2018, 07:27 PM
Normal. I have seen those check valves too.
Old 07-02-2018, 07:32 PM
Formerly known as Syzygy
Canada Kev's Avatar
Mine does it for the first few starts in the spring after winter hibernation. I think that in my case it's likely the fuel stabilizer I've been adding for winter storage. After I get that winter tank used up and filled with fresh gas, it doesn't happen any longer. It never did it before, but the last two springs it has, which coincides with the current bottle of Stabil I have. It's almost gone so we'll see next April...
I know this probably doesn't help the OP, but it might be a bit of info for future reference for others.
Kevin
Old 07-02-2018, 08:34 PM
El Duderino
tirwin's Avatar
Yes, park on just the right incline and you’ll get a big puff. Jeff Gamroth (Rothsport Racing) makes a check valve that goes in the S tube from the oil cooler to the tank. I believe it’s modeled after the same design used in 964’s (I think?). Pelican sells them. Search for oil inlet check valve.
It doesn’t hurt anything. Except I fumigated some people at a car show once. I called it a Porsche baptism.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-02-2018, 09:42 PM
SCadaddle's Avatar
Old 07-03-2018, 01:30 AM
Bill Douglas's Avatar
I thought "Holly smoke" one day. The car went br br br brrr brrr brrr brrruuuummmp brummmm and clouds came out of it. I thought something had broken but I think it was just a weird occurrence of a valve not completely closed and the angle of the road, and a LOT of oil draining into a cylinder.
Old 07-03-2018, 02:02 AM
Thank you guys.
Old 07-03-2018, 03:42 AM
'73 911 T Targa
As the risk of demonstrating my lack of knowledge...
Just what path does the oil take to find its way into the cylinders?
I'm guessing through the valve guides and then through an open valve?
Old 07-03-2018, 05:21 AM
Functionista
manbridge 74's Avatar
Puff is normal, harms nothing and extra oil might prevent more wear since cold starts are where most friction is. Check valve? Seriously?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-03-2018, 06:40 AM
wreckah's Avatar
i think: flat six = cylinders horizontal...oil gently seeps past rings (from crankcase into cylinder)
the puff is bigger the hotter you turn off the engine. So when you have just seriously flogged it, park it up, and then it will have a nice cloud of smoke the next day
before: '69 Porsche 911T bahama yellow
now: 1981 911 SC Targa winered
Old 07-03-2018, 07:27 AM
Topocalma
I have the same issue on my Turbo. Not always, and quite a lot of smoke at first start. To the point that I had an enraged neighbour telling me I was poisoning his children in the underground garage.... I'll try the 'Porsche baptism' line next time he pipes up..
1973 2.4T gemini blue
1977 3.0 Turbo slate grey
1973 2.4s motor rebuilding project
Old 07-03-2018, 07:57 AM
'73 911 T Targa
OK, let me have another run at displaying my lack of knowledge...
I thought most of the oil was in the tank. No?
Old 07-03-2018, 08:33 AM
theiceman's Avatar
this is the reason I don't back my car into the garage , as the garage is attached to the house. The yelling from inside the house usually lasts longer than the smoke so I decided to park in front way.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-03-2018, 09:16 AM
SCadaddle's Avatar
If, after driving the car, you let it idle for a couple of minutes to let the scavenge side of the oil pump do it's job to scavenge the oil in the engine case before shutting it down, you might be amazed at the lack of the puff of smoke on the next start-up.
Old 07-03-2018, 09:46 AM
nene's Avatar
I keep reading about the "smoking gun". Back in my high-school day (circa 1986) when I had my first 1975 911S with approximately 86k miles, which I drove for nearly 5 years, I do not recall once when it ever smoked.
Old 07-03-2018, 10:56 AM
El Duderino
tirwin's Avatar
My experience is that there are at least 2 separate things that can cause excessive smoke on startup.
Oil can migrate from the tank back to the crankcase. My experience was parking on an incline -- pretty sure it was nose downhill with left side lower than right. In this case, the oil level in the tank runs down the S tube back towards the oil cooler. This is what the Rothsport inlet check valve is designed to prevent from happening. It basically only lets the oil flow one way. Any positive pressure and the check valve opens, allowing oil to flow.
I found the thread where Jeff Gamroth commented. He said it's basically the same design as what's used on the 996/997 turbos.
The other case is when cold control pressure on CIS cars is too low. In that case you end up dumping excessive fuel in a cold start.
Old 07-03-2018, 11:54 AM
Senior Member
Superman's Avatar
Normal. It is part of the engine design.
If you want to know whether oil is getting past the valve guides and seals, one way of evaluating is to cruise down a steep hill for a distance with gravity as your only power, foot OFF the gas, and then look in the rear view mirror when you finally put your foot back on the gas. If oil has leaked past the seals, then you will see blue smoke.
But yeah....smoke on start up------> Normal.
Mocha 1978 911SC. "Coco"
Old 07-03-2018, 06:33 PM
Eva
911SauCy's Avatar
I GENUINELY laughed out loud reading this thread title...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 07-04-2018, 10:55 AM
