3.2 fuel line replacement
Is there a way to change the cross over line that runs between fuel regs with out dropping engine?
Thanks Bill |
That Guy
Remove the intake manifold. Its not that difficult.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
1988 Carrera
there is a guy on this site that makes a fuel line that you can use and do not have to remove the manifold.
His name is Boxtser I think. Others will chime in
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
I'm doing it now. You do not have to remove the manifold.
One the drivers side I removed the heater fan. On the passenger side I removed the air cleaner. It's pain to get to but not that bad. The challenge I am working on now is getting a good seal on the side easiest to reach (passenger side). I think it's an issue getting the fitting to seat due to the angle. Len Cummings (and probably others) make the fuel line. Last edited by billh1963; 07-05-2018 at 07:51 AM.. |
Thanks all, I was able to get it of as per billh1963 skinned knuckles but all good!
Thanks for the quick responses Bill |
If you have a bit of time you can get a cheap inspection camera that plugs into your phone off amazon or ebay. Might come in handy for this. |
