7783911's Avatar
Oil Regulator to trombone coil
Can anyone tell me if this regulator has a thermostat in it? I ran the car and the pipes to the regulator were hot (burnt fingers) but the lines to the trombone were cold. I wasnt quite at 190 so wondered if some valve wasnt opening. I also noticed a small king in one line (looks like someone put a jack in the wrong place:-() but doesnt appear so kinked as to be a blocking factor. Now those lines to the regulator are close to the engine and I guess their temperature could be engine heat transfer?
I hope to get out for a long run today to get to 200+ and then retest front but may as well know if the regulator could be a culprit
thanks
Old 07-09-2018, 06:16 AM
Hilbilly Deluxe
emcon5's Avatar
You mean the thing in the right rear wheel well?
Yeah, it is a thermostat.
82 911SC Coupe
GTI Cup #43
Old 07-09-2018, 07:03 AM
Charles Freeborn's Avatar
Yes, thermostat. Should open at 185ish...
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 07-09-2018, 09:10 AM
It should open at ~190F. If you were not at 190F, then that could be why.
'79 911SC Targa
Old 07-09-2018, 09:12 AM
7783911's Avatar
will do long run an get above middle mark which according to gauge is 200
thanks
Old 07-09-2018, 09:50 AM
