Ac thermometer type?
I am looking a LED/DIGITAL thermometer to test my AC coming from the vent-I prefer something that will stay in the vent as well as measure the temp in the car.
What are you using ? brand and model?.....I have tried several but they keep failing me Thanks in advance! |
https://www.amazon.com/gp/product/B007FSG72K/
I stick the probe in the center vent, and set the thermometer on the floor between the seats. It only updates about once a minute, so it's not great for fast changing temps, but it's stable and the batteries last for YEARS. And, $12 is pretty nice for a 2 temp thermometer. |
What should the probe temp read?
Here is another option, Harbor Freight $5.99 before 20% discount
https://www.harborfreight.com/instant-read-digital-thermometer-95382.html http://forums.pelicanparts.com/uploa...1530812832.jpg |
Actually I did the same. When I was building the A/C system in my car I had one of these thermometers shown below. I ran the sensor on the evaporator to see how cold it was getting, and also taped the sensor to my passenger side view mirror to get outside temperature to calculate the difference from inside to outside.
Good Luck with your projecthttp://forums.pelicanparts.com/uploa...1530827111.jpg |
I rebuilt most of my stock system and converted to 134 a. I get an average of 53-55 degre s from the vents on a hot SO Cal day. I replaced the compressor, dryer and the expansion valve. Oh and the thermostat switch from Griff. But to be fair my car is black on black. Really tough to cool.
Keep in mind, the temp is also dependent on the blower speed. My custom setup with PLENTY of condenser only goes to about 50 degree vent temps on a 95 degree day, but the blower is the Keuhl Windstorm blower, which is wired directly via a relay, so it's getting full battery power at all times (one speed, "rockin' out"). The vents might only be 50-52 degrees, but they blow that 50 degree air into the back seat :D
Plenty cold. If I had a stock blower on low, it might drop those vent temps 10, maybe 15 degrees. |
50 deg vent temps at 95deg 80% humidity and will freeze you out! The air volume is incredible. Have checked the performance chart in the factory manual and it is performing exactly to spec. My '80SC AC is not installed at the moment, but I have the Kuehl Windstorm blower waiting to be installed. |
I have a blower motor from GM trucks & SUVs installed - don't know for sure how much more airflow over the stocker, but is somewhat more. I get 27-28 degree vent temps in upper 90s weather with blower on max, but I do have a 3 condenser system (all with fans). Of course, you guys already know that as I crow about it every chance I get. :D
The tiny ducting in 911 systems definitely sux - looks like Jonny's evaporator housing/blower components improve on that; will have to reverse engineer that at some point, as I can not even dream of affording his gear. :) |
| All times are GMT -8. The time now is 09:22 PM. |
