Front A/C condenser air flow.
http://forums.pelicanparts.com/uploa...1531069407.jpg
^^^^^ It has been suggested on a previous post that cutting 1-1 1/2 inch round holes across the front condenser shield improves cooling. I can't find the post. Any thoughts? Thanks in advance. Gerry |
Can't you just remove it?
Gerry, I just serviced my 85 AC and it works well! But not well enough to take on a drive in the heat. I get 55 through the tiny vents on a hot SO Cal day. Terrible AC . I just drive when it’s cooler in the morning or evening.
Condenser shield.
But, it also acts as a stone guard, so decisions-decisions........... Best. Gerry |
Hey Doc G,
Replace with chicken wire mesh, paint it black and you will still have some protection. :-) Not Concours but you may get a few degrees lower temps :-) |
Good idea. |
A/c
Gerry |
I went underneath my car this weekend and saw a new dent in my stone guard. Not sure how it got there but sure glad as hell that it was.
I say go the Tim “The Tool Man” Taylor route, MORE POWER! Try and find a front blower motor that puts out more CFM than the one you have. I am not sure what our squirrel cage blowers put out but I know there are 12V DC blowers that can do 450 CFM |
I'd suggest before you go cutting any holes you get some empirical data: using an anemometer to measure air flow; create a grid of cells and measure the air flow in each cell. |
Condenser shield.
And thanks for your thoughts. Having compared (just by hand), the airflow does increase without the factory screen by quite a bit. Some of the airflow may be getting trapped between the condenser and the screen. Unfortunately, there no way to measure A/C performance with, or without the screen under identical ambient conditions. Best, Gerry |
You can observe the high side pressure, if it drops then in theory you have an improvement. Loosen the 3 ten mm head bolts that hold the perforated grill. Toss on your gauges. Note the high side reading at idle when clutch is engage. Remove the grill, and use one fastener on each end to hold up the condenser. Observe the gauge readings. Griff |
A/c
And, thanks again. Best, Gerry |
i would put a fan in front of the car to simulate driving conditions.
check hi side as suggested, at a steady 1500 or 2k. then remove the cover and check hi side again. |
Test for the worse case scenario.... not when the car is driving down the road,
not with fans that are not there when you are driving, and not at 2000 rpms. Idle, at stop light is the worse scenario. Driving slowing in traffic is the second worse scenario. |
the system was designed to work when driving,.
the compressor is turning too slow, and air flow is inadequate at idle and sitting. you also spend most of your time moving, not sitting so why test it sitting or charge it at idle and with very poor air flow. AC in a Porsche was an after thought and the design reflects it, also lack of space. if the guard does not restrict air flow when driving but does when sitting, leave it on. it protects the coil. just so you know I have been to HVAC school and I am not just blowing hot air. you check load current of both evap motor and comp along with clean filters to make sure there is proper air flow and the comp is operating as it should be. same with cars, the comp needs to be above idle and with the very poor air flow on the coils of the 911 extra air flow is needed for them to operate as designed. |
True, refrigerant flow and air flow over the deck lid condenser improve with RPM's, but the front condenser has a fan sucking air in from behind the front bumper and it blows down over the front condenser ...... because rather than "design" a condenser that gets air force directly through it would required a change in the entire front vehicle looks. Quote:
This you can ask of our clients. Quote:
Gee, I'm kinda missing Willy, where is the love? |
| All times are GMT -8. The time now is 04:15 AM. |
