Just when you think you are getting ahead...
Turned on my headlights this evening and to my surprise my headlight washers sprayed my freshly cleaned car/windshield leaving water spots Never checked to see if they worked before, but now I'm sure they do, but why when I turn on the headlights? They spray when the light switch is just hitting the running light switch postion (half way pulled out). Getting ahead... I did some work on my car today (nothing that I would think could cause the problem): Removed my vent blower fan (left the 4 pronged connector unplugged, connectors are recessed). Reversed my windshield wiper arms. Began removing air conditioning system (components in the engine compartment). Any idea what could be causing this? Though I rarely clean the car or drive it at night for that matter, it's anoying none the less. Thanks, Gordo
Don "Gordo" Gordon '83 911SC Targa |
RETIRED
Cut the wires to the pump.....then gently remove said pump, take to nearest large body of water and give it the sacred float test....if it does not sink, give it mouth to mouth to resusitate, then re-install and live with it....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 02-28-2004 at 08:34 PM.. |
Gordo,
Did you ever figure this out? I assume it's a grounding issue, but don't want to chase my tail. Yes, I realize this post is 14 years old.. Thanks, Matt |
'82 SC TL
Rather than "cutting" the wires, just disconnect the headlight washer pump
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Hasn't the tank long since run dry?
Matt,
The headlight cleaner switch is powered when the headlight switch is in park or on positions (fuse 7 block 2). If your headlight washer switch was left on or it has failed in the closed position, then power will get to the headlight cleaning relay and energize the pump. I am basing this in my 1985 and similar vintage car. Mike |
