Can you tell what size the wheels are, without taking the wheels
off of the vehicle? People like to guess, but I want to know if there is another way instead of jacking the car up and taking the wheels off.
Hi, if you post a picture i can tell you what size the rims are ..if that is the Q? Of course it must be Fuchs...
Ivan |
as Ivan indicated, 16x6, 16x7, 16x8 and 16x9 inch fuchs each have unique features that make it relatively easy to distinguish from fotos -- suspect the same can also be said for 15" fuchs . . .
PM sent. SmileWavy
for a '76 Carrera oe std was 6 & 7 x15 185/70 & 215/6 option1 was the same tires on 7 & 8 option2 was 7 & 8 w/ 205/50 & 225/50 tires your picture appears to show 7 & 8, probably option 2 tires but hard to tell from here |
The tires read 205/50 & 225/50 ZR 15. The ZR 15 is what? |
One last question in regard to the finish on the fuch wheels. Does anyone have a pic of what the Turbo finish and the outer barrel polished and then (milky clear) anodized looks like?
Z speed rating
R radial 15 wheel diameter |
Nice looking car you have there BC
What does the tire say????
Option 2 was a one year only choice that was the most efficient every offered. |
225/50 zr15 |
I am in the process to restoring the wheel to originality. Doing it myself. Bill, this is what I have been told: First, the spokes anodized and the outer rough offset with the smooth lip. (similar to the 74-77S but wider wheels) Second, the center black with the outer rough offset and smooth lip. (like 75 Carrera USA) Third, the center black with the offset and lip smooth. (Like 75> Turbo and all 16" wheels) I want to do the third option but I don't know what the finish looks like. What is the Turbo finish that has the outer barrel polished and then (milky clear) anodized? This became available as a option in 76 but very few had them. |
| All times are GMT -8. The time now is 04:42 AM. |
