-   -   Replacing clutch helper spring. Missing part in PET? (http://forums.pelicanparts.com/porsche-911-technical-forum/1002062-replacing-clutch-helper-spring-missing-part-pet.html)
Alex599 07-11-2018 08:19 PM
Hi fellow Pelicans,
I’m in the process of changing a broken clutch helper spring and am having a hard time finding a rubber seal on PET. If you look at my picture, you can clearly see a seal on the charge arm but in PET it’s nowhere to be found. Worse case scenario I can reuse the old one but I’d like to replace it if possible. Any thoughts?
http://forums.pelicanparts.com/uploa...1531369076.jpg
http://forums.pelicanparts.com/uploa...1531369117.jpg
timmy2 07-11-2018 08:40 PM
3 sealing rings listed as required for an SC, only 2 shown in drawing a possible clue?
DRACO A5OG 07-11-2018 09:03 PM
Two goes into Bell housing at fork & shaft and one as pictured, there is no dust guard between Omega and Clutch Arm.
proporsche 07-11-2018 11:26 PM
there are always 3 seals and the seal must be on the little finger to prevent dirt going into the vertical shaft and keep the lube inside ....
If you look on your PET it is written it takes "3"
Ivan
Alex599 07-12-2018 05:42 AM
Ivan
Ok, so I guess they only appear to be of different size due to them being worn? The one between the clutch release lever and et bellarm seems way larger than the one sitting on the change lever. Where does the third one go?
theiceman 07-12-2018 06:15 AM
i put one of item (4) above the helper arm , and one below the helper arm , and called it a day.
proporsche 07-12-2018 10:34 AM
one goes on bottom of the fork and the next on top of the clutch arm and the 3rd on top of the finger..
Ivan
zje 07-12-2018 05:49 PM
Same. I used 915-301-139-00. Interestingly enough there was no old seal above the helper arm when I did this.
theiceman 07-13-2018 06:11 AM
I didn't think there was either on mine, but when I got in there I found some hard remnants, long ago vulcanized through heat and the elements.
