-   -   Heat exchanger issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1002205-heat-exchanger-issue.html)
Targatogo 07-14-2018 03:14 AM
Hi - my heat exchanger has a small movement between the body and the pipes that leave it - should that be the case? On accelerating there is a burbling noise as if exhaust leak. Is this where it could be coming from? When running a constant speed there is no burbling noise!
75 911s 07-14-2018 06:12 AM
There should be no movement. The HE should be rock solid tight to the engine. Can you post a video on youtube and link to here of the movement? The gurgling could definitely be an exhaust leak.
DRACO A5OG 07-14-2018 09:05 AM
OP, it sounds like you have an exhaust leak, +1 post a video or pictures.
Targatogo 07-14-2018 09:26 AM
Hi - link is https://youtu.be/98fRdVVy-BM
You can see the body of the heat exchanger moving up and down the inlet tube. The exchanger tube is secure to the engine as I have checked all the nuts.
Thanks for you help......
Targatogo 07-14-2018 11:16 AM
Hi - posted here https://youtu.be/98fRdVVy-BM
Not great quality but you can see what is happening.
cabmandone 07-14-2018 12:09 PM
What year is your car?
Targatogo 07-14-2018 01:26 PM
1982 - I have posted a video, just waiting for the mod to clear it......
cabmandone 07-14-2018 04:47 PM
Okay. You can have some movement in the metal on the H.E's but that would be a tinny rattling sound. In some cases an off exhaust note can indicate a broken head stud. Does it make the noise more under heavy acceleration?
Targatogo 07-15-2018 02:48 AM
Yes - more noise under acceleration. Can't hear much when running at a constant speed. Engine was rebuilt 30 months ago and new heat exchangers installed.
Flat6pac 07-15-2018 02:59 AM
Sound of head studs loose or broken because the 82 uses inserts into the heads so exhaust leaks aren’t like burned out exhaust gaskets of the thin flange heat boxes.
Bruce
Targatogo 07-15-2018 03:03 AM
How easy is it to check the studs?
cabmandone 07-15-2018 05:12 AM
Take your lower valve covers off and you'll be able to see the usual suspects. If the engine was rebuilt I doubt it's broken studs since they most likely would have been replaced.
If you're still using a 2 out 1 in exhaust I'd suggest checking all the joints and verify the exhaust barrel nuts are torqued appropriately.
If you can get the car up on a lift or on some jack stands, I'd get under it and look for any carbon deposits from a leak. If you've put any miles on the car, it should be pretty evident where the leak is.
Targatogo 07-15-2018 05:45 AM
Ok - thanks for your advice. Something to get my teeth into during the week.
cabmandone 07-15-2018 08:54 AM
OOPS! I meant two H.E's into a single point on the muffler, not two pipes out from the muffler. This is why I shouldn't post until after my second cup of coffee. Good luck! I hope you track it down.
Targatogo 07-16-2018 08:13 AM
Have a look at the issue...https://youtu.be/98fRdVVy-BM
cabmandone 07-16-2018 09:23 AM
HOLY SMOKES that's a lot of movement! The old rusty pair of H.E's I had didn't have that much play in them.
Targatogo 07-16-2018 09:52 AM
I know - the other side is rock tight. The rusty one I have in the garage is rock tight too. So .... is that the cause of the exhaust blow rather than a broken stud?
DRACO A5OG 07-16-2018 10:42 AM
The stainless steel shroud does not get any exhaust, it just radiates and keeps heat from the pipe in so when you open the heater flaps it can blow in hot air to the cab.
Most likely the weld that held the HE in place broker off and taking pipe material with it.
Search for a good used one. Block off outlet and pour water into it, if it does not leak you will be good to go.
Sorry time to remove HS and replace. Make sure you get new nuts and gaskets, Might as well do both gaskets and inspect the other side for rust too.
cabmandone 07-16-2018 11:49 AM
I'm wondering if what you're hearing isn't a rattle. That shroud should never have exhaust gas in it since it's what delivers heat to the cab. Take a few finish nails for wood trim and place them between the exhaust ports and the shield just to hold the shield tight and then go drive it. I would find it hard to believe you have a head stud issue unless the original studs were used rather than replacing. Could still have a bad exhaust doughnut somewhere but I'd start by temporarily getting the shroud tight and see if the noise goes away.
Targatogo 07-16-2018 12:53 PM
Ok - tomorrow I will tighten it up with some exhaust putty and then go for a run to see what happens then. It could be that the HE is rubbing up and down on the pipe and making a noise (there is some noise in the video when I was moving it up and down). Be annoyed if I had to replace as this one was fitted new 30 months ago! Once again, thanks for your comments and advice. I will update asap.
cabmandone 07-16-2018 02:56 PM
I'd think that worst case you'll have to drop the HE and have a shop tack weld it back in place if that's what ends up being the problem.
Targatogo 07-18-2018 08:36 AM
Ok - so that was not the problem! The exhaust putty worked a treat and the exchanger is rock solid. will have to check for exhaust leaks from the whole system before taking things apart. Wondered if the cat had packed up?
DRACO A5OG 07-18-2018 09:20 AM
Outstanding.
If cat clogged, you will feel it in poor acceleration or glowing red hot temps on the cat.
cabmandone 07-18-2018 09:40 AM
Look around for any carbon buildup on the exhaust joints and at the manifold gaskets. Like Draco said, if the cat was gummed up, you'd notice performance issues as well as a glowing hot cat. Good luck and keep us posted!
Targatogo 07-18-2018 09:56 AM
Will do - thanks for your support and advice......
Targatogo 08-04-2018 09:52 AM
Ok - so not an exhaust issue so have created a video of the sound when engine running. As you can hear, when increasing revs steadily no noise, give the accelerator peddle a pump and you can hear a noise - any ideas? Do you think it is a valve issue, ignition issue or (dreading this) a bearing issue?
https://youtu.be/QlETDee7s8c
cabmandone 08-04-2018 10:06 AM
Link to video doesn't appear to be working.
DRACO A5OG 08-04-2018 11:06 AM
+1 Link broken, make sure it is in public to view
Targatogo 08-04-2018 02:07 PM
Sorry folks - link should now be working....ticked the wrong box!
pmax 08-04-2018 02:30 PM
Remove the lower valve covers and have a look at the head studs.
DRACO A5OG 08-04-2018 02:50 PM
Uh oh,
Sounds like a head to case leak, maybe cam tower.
+1, remove covers and inspect studs or if you can do a leak down test. That will certain show a leak and pin point were it may be coming from.
Sorry to see your troubles Brother :-(
Targatogo 08-05-2018 01:04 AM
Thanks for the suggestions. Friend of mine suggested chain tensioner may have collapsed. What do you think?
Looks like a lot to investigate!
DRACO A5OG 08-05-2018 06:48 AM
That is possible since you have the SC, if you do not know the complete history, you will not know if PO put a tensioner guard or updated them to a carrera oil fed ( you would see oil line going into the chain covers )
You can remove the covers and inspect the tensioners to make sure.
Targatogo 09-29-2018 12:07 AM
Hi everyone - just thought I would update on the issue. After a leak test two cylinders were well down so engine had to come out - no loose bits and pieces anywhere, studs all good etc. Problem has been identified as blown head gaskets - the springs inside two had gone bad and two others were in the process of failing. So - new gaskets purchased and ready to go in - just a question - is there a 'right way' for the gasket to go? One side appears flat and the other side slightly curved.
cabmandone 09-29-2018 02:44 AM
I don't recall. You might consider sending a PM to Bruce (flat6pac) or John Walker both would probably know for certain.
Targatogo 09-29-2018 03:16 AM
Thanks Cabmando - can't find flatpac6/John Walker PM as the area had been disabled by administrator! Can you provide a link for me?
DRACO A5OG 09-29-2018 07:59 AM
Post a pic of your old gasket and new one.
Targatogo 09-29-2018 10:35 AM
Here is a picture of the one that blew -http://forums.pelicanparts.com/uploa...1538245894.jpg
Targatogo 09-29-2018 10:38 AM
Ooops - last post is a new one, this is one that blewhttp://forums.pelicanparts.com/uploa...1538246161.jpg
Targatogo 09-29-2018 10:40 AM
On a new one there is a 'flat' side which does not show up very well.
