-   -   Speedometer wire disconnection (http://forums.pelicanparts.com/porsche-911-technical-forum/1002227-speedometer-wire-disconnection.html)
bcgreen 07-14-2018 09:30 AM
How to disconnect this black cable? I don't want to yank on it and destroy something.
http://forums.pelicanparts.com/uploa...1531585820.jpg
fintstone 07-14-2018 11:20 AM
Looks like the ODO reset cable. Might be easier to disconnect on dash (other end).
bcgreen 07-14-2018 11:33 AM
Is it a pull or twist on the other end?
fintstone 07-14-2018 11:36 AM
Most folks disconnect at the dash but you can remove at the gauge as well.
To pull from the gauge. Best to put knife or thin screwdriver under it and gently around it to work it up. This is what it looks like removed.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/961388-wtb-911-odometer-reset-cable.html
Don't just pull by the cable or you will screw it up (hard to come by). Also, don't use pliers on plastic and break it.
bcgreen 07-14-2018 12:03 PM
Thanks worked great.
