-   -   Another window switch problem (http://forums.pelicanparts.com/porsche-911-technical-forum/1002553-another-window-switch-problem.html)
migbr7 07-17-2018 03:55 PM
Hi all. I recently replaced my old door panels with leather rs ones. Anyway, I had some difficulties reattaching the window switch wiring but with help on here got the connections right. So I had reattached the wires and was rolling down the window using the switch and bang, a spark from the wires and a small puff of smoke and the window stopped. Switch no longer worked. I thought I’d better order a new switch and I just got it. That doesn’t work either. 😩😩😩. Anyone have ideas how to figure out what the problem is and how to fix it????
walt 07-17-2018 04:05 PM
Sounds like a short. Did you check the fuses?
migbr7 07-17-2018 04:41 PM
Yes. 😩😩😩
RSBob 07-17-2018 09:41 PM
Smoke is not a good thing. Check in the area you saw/smelled the smoke for burnt/fused wires and replace. Triple check your wiring to the switch is correct. Me thinks you transposed the wires.
I bet your new switch works so replace an existing switch with it and give it a try after you carefully document which color wires go where.
88911coupe 07-18-2018 05:49 AM
Not sure if this is your problem but I chased a non working window switch issue for YEARS on my '88. At some point I decided to dig into the wires themselves...turned out to be there was a "kink" in one of the wires where it entered the door. It would randomly connect and disconnect which made trouble shooting a total waste of time. You say you did some work on the doors so maybe check that? Good luck.
930cabman 07-18-2018 05:37 PM
+1, I have chased the same for several years (not too hard) to no avail. Many of our rides are 30 - 40 - 50 years and older. Wiring can only hold up so long. Ideally our older machines should be completely rewired.
brianlay 07-18-2018 06:25 PM
Sounds like you took apart a working window switch. Mis-wired it when re-installing it and possibly applied power across the switch contacts.
Sounds like you need to troubleshoot with a schematic and DVM
Dpmulvan 07-19-2018 06:09 AM
http://forums.pelicanparts.com/uploa...1532005672.jpg
Dpmulvan 07-19-2018 06:10 AM
http://forums.pelicanparts.com/uploa...1532005825.jpg
Dpmulvan 07-19-2018 06:14 AM
Apply 12 volts across blue wires to check motors, if they work then work your way back up to the switches. Double check all your connections.
migbr7 07-20-2018 08:40 AM
Thank you all for your thoughts. I’m working on it 😩😩😩😩
