Munky King's Avatar
Fueling system requirements for 48 Weber’s in my G body
They say do it right, do it once, soooo
I’m looking to put a new fuel storage and supply system in my ‘75S - converting it to a twin 48 Carb set up.
I need to buy a new fuel tank, as the old one is rough and was thinking that I would upgrade the lines at the same time.
The car that is donating the engine, currently uses a fuel cell, with some sort of surge tank between twin external electric fuel pumps. I need to check around for a fuel pressure regulator / gauge.
Question is, for a road car, what do I need?
Can I use a similar two pump setting with a stock fuel tank? Do I need dual fuel pumps and surge tank on a road car where only occasional spirited / AutoX type driving is ever likely to happen? The 48s seem to be somewhat thirsty (currently making about 280bhp) through a 2.8 high-ish compression engine (I know - higher compression and road car...).
Thanks for any insight. I’m still very much learning all this stuff. Ref the above engine choice if you don’t believe me!
Flame suit on...
Have I disabled cookies? Well I’ve eaten the heads off a few gingerbread men...
Old 07-18-2018, 11:01 AM
