Alternator - again - cause?
Hey gang
My 1985 3.2 Carrera is about to get its 3rd alternator in a year. All warranteed since the initial replacement. Also replaced battery when i did first fix last year. Also had all work done by excellnt mechanic
Im currently (pun?) im an overcharging situation where it will go from normal to 16 even 17 volts.
Is there anything common that can be causing this? I know the 3.2 alternator arent the most stable but this seems like more than bad luck with the alternator itself
Thoughts? Thanks
Old 07-18-2018, 07:50 PM
All failed in the same way...overcharging?
Old 07-18-2018, 08:47 PM
with the ignition on but not running, the alternator light is on?
The correct bulb type is being used for the alternator light?
Old 07-18-2018, 08:52 PM
Assuming the regilator was changed with each new alternator (it's integrated) then there is a voltage drop on the signal going to D+ on the regulator.
The regulator sees a low voltage and causes the alternator to overcharge.
Old 07-18-2018, 08:57 PM
Brianlay - no the first failed in the classic stuff faded while on long drives and then the first replacement bith overcharged and then faded. This one the car runs beautifully but the seatbelt light started popping on now and then so i started measuring and found the overcharge
Otherwise I’d have never noticed whereas the other ones were noticeable alternator not working
And yup - bulb correct and on
Old 07-19-2018, 05:34 AM
What can cause that voltage drop to d+?
T77911S's Avatar
what brand is it
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-19-2018, 05:44 AM
shh-the robot is sleeping
Glad to hear you are not getting Charged... for replacements.
'88 911 Coupe, 69k miles
Old 07-19-2018, 06:19 AM
Dont know the brand. And yeah - very glad the warranty is being honoured
Old 07-19-2018, 06:54 AM
