Fan Pulley Parts question
This is hard to look up as the parts listings on this site are only going to recommend what is correct for the year.
I have a 78Sc with the smog pump long gone. I have a bent outer pulley half on my fan belt/alternator and it causing wobble so I want to replace it. I may as well clean it up in that area, can I use a pulley half off a later SC that did not have a smog pump ? I think the smog pump was only around until the SC with the Lamda sensor came out then it was only a single pulley . Anyone know if I can do this ? Thanks
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
ice..use this one and you will be ok..smog pump in over the big pond was only in 1978-79..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks Ivan , hope I can source that one here. what year did you pull that pet pic from so I can snag a P/n ?
Hi This is from from 1981 up..here is your number
93010620902 ivan
lol thanks ,, just coming back to say never mind I found it , you sure are quick
