Oil temp sensor compatibility- numerical gauge
1982 SC. My oil temp gauge is the numerical style and I want to replace the temperature sensing unit in the engine. I am getting conflicting part numbers from Pelican’s catalogue and Porsche PET. I am trying to plan ahead and make an order of parts. Unfortunately, I don’t have access to the car for a while and can’t pull the gauge for more info.
What’s the best way to determine which sender is compatible? Thank you, Sent from my iPhone using Tapatalk Pro |
The 82will have a chrome sensor with a 911 part number.
The early sensor is brass and has a 901 part number The numerics on the dash can be either as there was a time selling both units to install in dash with sender. Bruce |
Going through the pet it looks like the date stamps is most important
I recall a 77 had numerics and used the later sender. Bruce |
There was a posting recently about the temperature topping out different depending on the year of application
Oil temp
I know the one on the left was out of a 69 but they’re both early to go with the brass 901 part.
Bruce http://forums.pelicanparts.com/uploa...1532291938.jpg http://forums.pelicanparts.com/uploa...1532292158.jpg |
Bruce-
Here’s the gauge I’m trying match the sensor to. I’d pull it an look at the markings, but I won’t be with the car for a few weeks. https://uploads.tapatalk-cdn.com/201...8cc6362a9d.jpg Thanks for any insight. Sent from my iPhone using Tapatalk Pro |
We know the brass one is good for 340 so it will have to be the chrome one that should already be on an 87 930.
Bruce |
You want sender 901.641.632.00. That temp gauge was used from 1974-1977. I'm pretty sure none of the SCs came stock with numbers.
As a double-check, I have the same temp gauge in my 1979. In my case, I bought it aftermarket, and it also came with a 901.641.632.00 sender. It is brass. Mark |
Bruce/Mark- thanks for the responses and information. I’ll report back once the job is done.
Will |
I often wondered if I had the right sender in it. mine is chrome .. dammit another project... |
| All times are GMT -8. The time now is 01:39 PM. |
