3.0 head rebuild
Hey out there. I am in need of some advice. I purchased a 3.0 from prince frederick about 3 months ago. The engine is destined for my wifes 911 sooner or later but that aside here is what I ran into. The engine had broken head studs so I decided to tear it down to replace them. While in there I decided to have the guides replaced put new rings in etc. 5 of the heads checked out fine but the last one had major pitting around the valve seat. It appears that even some of the aluminum casting is gone also. I am not concerned with that as much as I teach welding and could easliy repair that my self. The concern is can the seats be replaced on these heads with a certain level of reliablity? and if so can it be done at a cost that would warrent this option. If not could some one send me in the right direction for 1 replacement.
Ben
75 914-6 (2.7)
77 911s (3.0) someday I will finish
Old 03-07-2003, 09:41 AM
Super Moderator
cstreit's Avatar
A good shop can get them out and put in new ones...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-07-2003, 09:50 AM
Senior Member
I bought mine from (Had a cracked valve guide boss) from EBS for $195. Dan Petchel 609-298-7040 may also be able to help you.
EBS claimed it would not be cost effective to try and repair the head. At the time Dan did not have what I needed. I would call Dan first then go to EBS if Dan can't help you.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 03-07-2003, 09:52 AM
