Installing Recaro Expert M in a 76 930
I've got a Recaro Expert M Seat (part number LTW.00.000.YY11) that I'd like to install in my 76 930. The seat was previously installed in a 67 912 I had so it's currently got a slider and bracket that worked with the 912. I'm assuming I need a different bracket to match up to the mounting holes in my 76. Anyone know who supplies these? I'm in California. Another question would be if the sliders on my stock 76 seats can simply be installed on the Recaro seat? Here are some photos of the Recaro seat.
http://forums.pelicanparts.com/uploa...1532330570.jpg http://forums.pelicanparts.com/uploa...1532330590.jpg http://forums.pelicanparts.com/uploa...1532330605.jpg http://forums.pelicanparts.com/uploa...1532330629.jpg |
I had a set of Recaro Ideal C seats in my 86 turbo and swapped them out for Recaro LX. They used the factory sliders with a Recaro adapter.
The rails from your factory seat will swap over directly onto the base of the Reacro seat
Thanks. Indeed they do. Only problem is the release lever can't be pulled up high enough to the release the slider. The lever hits the front/bottom of the seat when pulling it up. I'll need to put some spacers between the seat bottom and the sliders.
