davis911s's Avatar
Question Generic oil lines??
I am going to replace some of the oil lines on the rear of my engine, such as the one from the oil breather. Can I get away with using non-Porsche parts here or no. Also if I can use other lines what should I look for? Does this line get hot?
Shawn
This is all in an attempt to try to get my car from leaking
Old 11-07-2001, 03:31 AM
Recreational Mechanic
Nickshu's Avatar
Post
A hydraulic hose shop should be able to help you here. The fittings on the Pcar are a bit more fine thread than what would be used in most industrial metric applications, so they may have to order some in. I did this for a flexible hose I used in my SSI install/oil line backdate. Make sure you price it out first though as you may find having custom bent hard lines may be $$$.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
Old 11-07-2001, 04:51 AM
davis911s's Avatar
Post
Nick
Thanks but the lines I am talking about are the small ones (no fittings)they have a hose clamp on them. I can't find a pic on this site or on my PET, but is the small hose 1" diameter approx, that attaches to the oil breather, the other one is very small and it is the drain for the airbox.
Shawn
Old 11-07-2001, 07:28 AM
