Getting wheel vibration at different speeds
So my steering wheel vibrates at different speeds, starting around 55mph. Then it goes away up until 75ish. Then it goes away a bit after that too. Maybe wheel imbalance?
Anything else I should check? |
I would check the driveshaft as well. Other members will chime in with their expertise.
Depending on the type of weights used to balance the tires, you could have lost a weight. I'd take it in and have the tires balanced.
But if its the steering wheel only then up front you have tire balance but it could also be tie rods. Jack the front of the car up and with the steering wheel locked move the wheel left to right and inward and outward to determine if you have any play/movement and if you hear any clicking from the ball joint. If its rear, the drive shafts are another items to consider beyond balancing. The big question is has the car sat in a single place for a long time? You could have developed flat spots on the tires. Check pressure and drive a bit but if you are driving at highway speeds and your tires are old with flat spots or more than 4yrs from manufacturer date on the tire its time for new tires. Old tires are dangerous, you could have flat spots, dry rot or a separation of the tread which could come off at highway speeds. Ctopher |
Always start with the tires, that's usually the problem. Could be a simple unbalanced/damaged tire or a bent wheel. I've also had similar vibrations cause by loose CV joints (on the hub side) and loose/missing motor mount bolts.
Does it drive like a dump truck?
Sorry; I couldn't resist. :D |
Any corrosion?
Check the front forward torsion bar sheet metal mounts too if everything else checks out ok |
I would do in order from cheapest:
wheel/tire balance check wheel bearing check for wheel round/true replace tires. ........ |
Check the lug Nuts
Sent from my SM-N950U using Tapatalk |
I’ll check those and then the tire/wheel balance next. The vibration is definitely only in the wheel. Tires are brand new. Thanks all for suggestions! |
Do this check first.
Road Force Balancing | MotorWeek Quote:
Torque is 96 foot pounds / 130 nm
year?
start with: old tires, flat spots, (mine had lots of them :)) balance then bent rim. a bad bushing in the steering column makes it worse. then I would look at tie rod ends. if you get it aligned (after new tires) the tech can tell if the tie rods are bad. also if you put tires on make sure they check for bent rims. Porsche rims are pretty stout. |
Start with rebalancing the wheels.
Like everyone else has suggested, start with wheel/tire balance. I had a set once earlier that never could get perfectly balanced; alway had a slight issue at 40-50. Turned out to be the tires. Be sure when you are testing the ride you are on a known stretch that is flat, and you use the same stretch each time.
Updates
Please provide updates by stage of repair/replacement. I see way too many requests for assistance then silence on the solution, which could help many others. Let us know the fix!
I have a similar problem, I suspect either old tires/poor wheel balance or worn CV joints/lack of fresh grease. I have a bit of an odd speed dependent roar from the back which could be axles/CV joints in a bind/worn (need fresh grease)? I can kinda “feel” the momentum of the car surge a bit that is commensurate with road speed. I had an alignment performed a few years ago and the tech said the front end was tight. |
Agree with most above.
But if it was my car, the first thing I would do is jack up the front end and spin the wheels. Check if the tread runs true. If it is the tire, you will be wasting your time getting them balanced. AHIK. Good time to check the tightness of the wheel bearings too. How long has this been going on? On my wife's car there was an imbalance that eventually ruined the front wheel bearings..... _____________________________________ Trackrash's Garage :: My Garage |
If your tires are out of round, no amount of balancing will help. At certain speeds, they will synchronize with each other and set up a vibration. A tire shop can check for out of round tires.
They used to have tire truing machines that would cut down the high spots on a tire, but they don't use those machines any more.... just throw the tire away and put on a new one. Tires are being made better these days, so there is less demand for tire truing. |
When the balance machine spins the wheel it's easy to spot things like bent wheels, out of round tires, tread seperation, etc. Just tell the technician to watch for it so he doesn't cover up the wheel when he spins it up.
Finally got my wheels balanced today and vibration is gone! Smooth as glass! Thanks for all input!
