-   -   Budget front oil cooler install using Carrera cooler lines??? (http://forums.pelicanparts.com/porsche-911-technical-forum/100357-budget-front-oil-cooler-install-using-carrera-cooler-lines.html)
Colby 03-02-2003 04:59 PM
I remember somewhere reading a thread where somebody recommended splicing Carrera oil cooler lines, and somehow attaching those to 16AN lines to run to a front oil cooler. The purpose being to avoid using expensive adapters. I can't find the article now.
Whoever is familiar with how to do this, could you please chime in? I have the RS bumper on, the Setrab cooler on its way, and need to start running the lines. Thanks!
Colby
Colby 03-03-2003 04:56 PM
Bump..someone has to know.
Elombard 03-03-2003 05:09 PM
I think I heard that Chuck at elephant sells direct adapters or something??
Colby 03-03-2003 05:15 PM
He does... at $80 for the pair. Not horribly expensive, but not cheap. Just curious as to any cheaper means, especially since someone had mentioned it in the past.
Colby
widebody911 03-03-2003 06:52 PM
Pegasus racing has adapters as well - for about $44 or so each, so you're better off getting them from Chuck.
