-   -   No Idle (http://forums.pelicanparts.com/porsche-911-technical-forum/1003626-no-idle.html)
nicholl911 07-29-2018 07:46 PM
No Idle
1974 911 with webers will not idle. Before the start, I pump gas, car fires right up then dies. I have installed a new gas pump, filter, lines, cleaned up carbs and removed old gas. What am I missing?
DRACO A5OG 07-29-2018 10:14 PM
Check fuel pressure. Pump may be defective, even Porsche Brand are a hit and miss.
T77911S 07-30-2018 02:53 AM
will it stay running if you keep your foot on the gas
has it been sitting for a long time.
may need a carb rebuild.
nicholl911 07-30-2018 03:32 AM
I have 3 psi at the regulator.
