I picked up some metal bushings for the gas pedal last night AND I think I may have found the water leak I've been having in the frunk. I was getting water in up front as well as water flying up from the pass front corner of the dash. Looks like the frunk seal was folding over at the top and the front area was completely missing. Going to replace the seal and bushings to see where we go next.
I've also begun discussion with Johnny from Classic Retrofit about putting an order together for the electro cooler AC kit. I had been kind of hanging back to see other people install it in hot temps like FL but I think I'm ready to move forward.
Current Cars: 87 Carrera RS/IROC Tribute, APR tuned 12 Beetle, 07 Ford Explorer, 91 Miata track car
Previous Cars: 00 Carrera, 01 996tt, 07 997tt
Instagram: @pdklol
Old 10-05-2018, 07:59 AM
Instagram: @pdklol
Old 10-05-2018, 10:15 AM
Last weekend we took the 911 and the miata out to the local PCA Autocross and had a blast. I took first in class over the other air cooled cars out there. Waiting to see the overall results listed. My wife and my friend ran the miata. My wife killed it out there and said she's ready to run again when it's a little cooler here in FL. It was up in the 90s that day. The last one is a quick video of my fastest run of the day.
auto-x
Instagram: @pdklol
Old 10-19-2018, 08:22 AM
I decided ahead of the AC system that I would do the headlights. The last few times I have taken the car out at night, I have realized the factory H5 headlights suck something aweful! Last weekend on my way to the local cars and coffee I hit like 3 different things in the road and wondered what they were because I did not see them coming.
I worked with Clay from Closed Course Motorsports who is incredibly responsive and was kind enough to set up a full DIY write up for his headlight build. For under $600, you can build your own headlights! Clay supplies the reflector shroud with city lights, and projector back-plates with hardware for mounting the projectors. You purchase those from him here-----> CCM Headlight Kit and he sends you a list of other parts with links to purchase them. Although I have not started this assembly yet, I can tell you that after review of his instructions, the headlights require some wiring and assembly skills of a DIYer. This is something I am looking forward to doing as I have always been big on DIY projects.
I have been doing a lot of headlight research and there are plenty of other great options ranging from $900-$2,200 as a plug and play option but lower cost and ability to assemble them myself attracted me to this route. I plan to do a full write up of the process and if all goes well, I will be helping my dad do his 89 930 with this kit.
You can reach Clay direct by email here: closedcoursemotorsport@gmail.com
His DIY for building the headlights is on his blog here: CCM DIY LED Headlights
Instagram: @pdklol
Old 11-07-2018, 06:19 AM
I really dig those lights. Way to go - first thing I will do when my car is back on the road.
Old 11-07-2018, 07:04 AM
Some of the parts have started to arrive! I'll keep you posted on how it goes for sure!
Instagram: @pdklol
Old 11-09-2018, 10:19 AM
rokemester's Avatar
Will you go with clear or more stock looking fluted lens?
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
2016 BMW 328i
Old 11-09-2018, 11:16 AM
Because the headlight assembly kit (111 941 037 C) comes with clear glass I will start with that look and see how I like it. It's only $25/side to grab some fluted H4 lenses (my initial preference).
The H4 rings arrived today and the CCM kit parts arrived yesterday. Today I should be getting the projectors and LED bulbs. Next week the headlight assembly kits should be here. I'm unfortunately about to get really busy with work and various other things around the holidays so I'm not sure how soon I'll be able to get started with this.
Instagram: @pdklol
Old 11-09-2018, 12:14 PM
OK so I started the process of the headlight assembly last week. My time is rather limited right now so I'm taking this in steps. I did notice a few things that were different so I'm going to cover another quick DIY here for the headlight assembly.
First off:
This post will cover just the headlight assembly. When I get tot he wiring, I'll post that in one chunk as well. So you need some space on a workbench to lay everything out and perhaps some towels to cover stuff up and prevent scratching. Remember that you are working with the internals of a headlight so you don't want to expose it to a lot of dirt or fibers from a old towel.
The tools I used were: flat head and phillips screw drivers, needle nose pliers, a portable band saw, a grinder, and if you want to make things go a little quicker than screw drivers...I used an electric driver. I laid everything out first and then sorted things around so that I was only starting with one headlight at a time.
The next thing I did was grab the pliers and start disassembling the Beetle headlight assembly. It's fairly easy to do. Basically you need to remove the spring clips from the inner and outer rings from the back side of the assembly. You also have two adjuster screws that help hold the outer trim ring (has springs on them) that need to be removed as well. The last piece is a turn signal housing that's held in by one single screw. Remove that as well (It's not getting re-used).
Below we have a shot of the headlight assembly removed and disassembled. Use the needle nose pliers to grab hold of the spring clips and push one side down to pull them away from the spot they are in and release tension slowly.
Now you will want to grab the Closed Course Motorsport back plate (this holds your projector in place). This is going to go inside the back of the headlight assembly with the silver ring on top of it so the spring clips can hold it together. In the photos below you can see where I have placed that in and put the spring clips in place to hold it all together. The backing plate is directional so make sure you have it so the notch and city light wiring hole are at the bottom side of the housing. 5 spring clips go back on and make sure they are laying in the proper orientation so they don't pop out.
Instagram: @pdklol
Old 11-16-2018, 08:50 AM
The next step is to grab a projector and disassemble it. This is pretty straight forward but there are 4 screws holding the black part and the eye lid to the chrome part and 3 screws holding the clip on to the back part of the chrome housing.
Once taken apart, Clay from CCM says to tighten down the threaded collar on the body of the chrome part and cut off the excess threading. I noticed that mine was slightly different from his and I only needed to cut the threads off and grind it down to a smooth edge. I did not have to drill pilot holes and re-tap them for the screws.
I ended up grinding it down a little more after this shot but you get the idea. The threads are cut off flat with the back of the collar. Next you will want to remove the collar as you do not need this part anymore.
Now you can clean everything up from the shavings and put it all back together!
Modified VS Un-Modified
Now you are ready to install the projector onto the CCM back plate! This is a really exciting part as the assembly will start to look like a headlight! The projector is bolted on by 4 bolts with 4 nylon spacers (helps dissipate heat) and 8 washers secured by 4 nylon lock nuts. I was able to assemble this on my own but it would help if you had an extra set of hands.
Instagram: @pdklol
Old 11-16-2018, 08:52 AM
Banned for Life
RSBob's Avatar
I had the same water leak. The issue is either a bad seal or corrosion in the channel which holds the seal allowing water in. You will need to remove the windshield and check out the channel and replaced the seal.
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
Old 11-16-2018, 09:00 AM
This is where things start to get fun. I struggled with this part of the assembly. Hopefully if someone does this after me, they don't have to struggle as much. Next step is to feed the CCM city light wiring through the back plate and place in the back of the chrome CCM shroud as shown below. At the bottom of the chrome shroud there is a circular tab that's supposed fit into the round hole at the bottom of the headlight assembly. I found this to not be the case after I installed the lens. For everything to fit together with the clear lens, the should tab was pushed back a little further in the assembly so don't panic about that.
Now go ahead and grab your H4 trim ring and lay it upside down on the work bench. Place the adjuster screws in the holes (qty 2) and then set the springs back in them. I used the black screws that came with the new trim rings. From here I placed the glass up against the headlight assembly (fluted lines at the top) and held it all together and laid it face down in the middle of the trim ring. It's important to note that you need to make sure the trim rings is in the proper orientation for install because it can be installed upside down. screw the two adjuster screws into the assembly holding the ring to the rest of the headlight. When you are done with install, these two screws should not be tight. They should just have tension on them. Carefully set everything together pressing the lens seal in the assembly and the trim ring on top of that. The trim ring kinda rolled over the edge of the glass on one side to fit snug. After you have everything in place, Install 3-4 spring clips to get the ring held on nicely. Clay says to not install any on the top or bottom. I installed two on each side kinda overlapping each other.
It's important to note that I struggled to get this all to lay together and fit right with the clear glass lenses that came with the headlight assembly. Supposedly the H4 lenses fit much better and I may end up going that route later but I wanted to see how the clear would look on the car first. Because the clear lens pushed everything back a little in the assembly I noticed that the silver and white parts of the assembly did not hold together as well as they did out the box. Clay suggested to run some self tapping screws though them so I will be doing that before I install into the car. The next step will be to do the wiring. Hopefully I'll be getting to it the following weekend.
Instagram: @pdklol
Old 11-16-2018, 12:15 PM
Thanks! I will check into that. Do I need to replace the metal in the windshield seal when I remove the glass?
Instagram: @pdklol
Old 11-16-2018, 12:21 PM
LED Headlights
Wow!
Those are really killer headlights. They are going to look so great on your "G" car!
Old 11-16-2018, 03:52 PM
Originally Posted by johnsonfm3 View Post
Wow!
Thanks! I just got them installed last night and up and running. I will post the last of the DIY as soon as I can. Super happy with the way they turned out.
Instagram: @pdklol
Old 11-26-2018, 06:01 AM
OK, so I was able to take a huge shortcut to the original CCM DIY and avoid all the major wiring for the job. This is all thanks to a friend of mine that does retrofit headlights for Toyota trucks. I explained what I was trying to do and showed him the DIY and he suggested this adapter wire kit. This allowed me to take the factory H5 plug and adapt it direct to the CCM headlight assembly. I also decided against wiring up the city lights as I'm already not a fan of amber lights and did not want to see more amber in there. I may wire them late to blink with the turn signals.
Here is the adapter I ordered. The smaller black plug worked directly with the projector controls for the high beam and I simply cut the larger black connectors off and wired them directly to the LED bulbs.
As you can see from here the blue one plugs right in to the H5 plug on the car.
The only thing I struggled with was the bulb actually fitting into the projector housing. As you can see below, the bulb is too large so I ended up having to sand the housing down to allow for the bulb to fit. I wish I had done this when the housing was all stripped apart. I'm going to go back in my DIY and make note of this.
Next was the horrible job of taking the H5 tabs in the buckets and bending them with a set of vice grips and then hammering them flat for clearance.
Untitled by William Reilly IV, on Flickr
And there you have it! The headlights are installed and ready to be fired up and aligned. I was seriously shocked that it all came together so well. As usual, the H4 trim ring mounting was a pain in the ass to figure out for the first time, but I learned that on my car, if you hang them on the top and then roll it to cover over the outside lip (on both sides of the car), you can have one person hold that side in place and have the other kinda hit the inside into place. There were clearance issues everywhere that I had to look out for but once we got it figured out, they held in place quite well. I guess time will tell. One thing you have to watch out for is the back of the headlight housing moving around in the assembly. I think we had to pull a headlight out twice to re-align the projector because we knocked it out of place while trying to mount the trim ring on the bucket.
A massive thanks goes to Clay from CCM for making this possible. I'll probably be doing my dads 930 next and a beetle after that with this setup. Next up for Bonnie is the electric AC system.
Instagram: @pdklol
Old 11-28-2018, 08:14 AM
Finally replaced the frunk seal this weekend and got around to replacing the crumbled plastic bushings on the bell crank for the throttle. The new ones are metal. I also had the car out at the local cars and coffee event the weekend before and they took a few nice shots of the car.
Instagram: @pdklol
Old 12-11-2018, 06:53 AM
I had been struggling with two leaks on the car and I think I finally resolved both thanks to the knowledge here on Pelican. The first was the trunk seal which I replaced last week. The other was water coming up on the dash from the bottom right side. I read several posts about what caused others to leak and decided to buy a new version of the URO seal to have it replaced. My OEM one was curling in and didn't look like it fit right in some places. I had my local windshield expert do the seal last night. When he took the OEM Porsche seal out, he found that it had been installed without any sealer on anything and could have been placed a little better. He said the OEM seal was as good as the day it came out of the package so we decided to go back in with the same seal and have it properly sealed along with a few of his tricks of the trade. He was shocked to discover that the paint job on the car and seal had been installed back in 2010. This goes to show how well the car had been maintained by the previous owners.
Instagram: @pdklol
Old 12-19-2018, 06:15 AM
scumbag
Looks great and i love the progression!
now that you have some more miles on them, how are you getting on with the lights? are they everything you hoped they'd be? room for improvement?
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
IG: @doktor_b
Old 12-19-2018, 08:01 AM
Thanks Chris! The lights are everything I hoped they would be. I still need to adjust them down a little but they are holding where they needed to be and have not skipped a beat.
Instagram: @pdklol
Old 12-19-2018, 08:41 AM
