Originally Posted by sedouglas72 View Post
Great news and great work! What was the ambient temperature when you were getting the 40 degree vent temps?
I'm pretty sure it was 80 degrees or so and rising during that photo.
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car
Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle
Instagram: @pdklol
Old 05-20-2019, 07:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
Almost forgot! I cleaned up the lug nuts and powder coated them black as well as added 7mm and 14mm spacers right before we went (Did longer studs for the 14mm without removing the hub ). Here are some quick pics from final prep and the trip! We had a blast.
When I changed the oil, the drain plug had some debris magnetized to it. Does this look ok? This is my first time changing oil on one of these.
Instagram: @pdklol
Old 05-20-2019, 08:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
No idea about the oil debris, but do love that last photo!
Old 06-06-2019, 11:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
MikeD930's Avatar
I wonder if there would be more airflow to the center and passenger side vent if the white colored 'Y' connector (shown in your photo below) is removed and separate hoses attached to the vents. Have you gave that any thoughts?
Also, are the screws for the Classic Retrofit bracket threaded into the blower case or is there a nut behind it? I forgot to check this out before I installed the A/C kit and have thought about replacing the Classic Retrofit bracket with a stock Bowden bracket.
Regarding the oil drain plug...I would take apart the oil filter to see if there are any abnormal metal debris. How many miles were driven since the previous oil change?
MikeD
'87 930
Old 06-06-2019, 04:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Thanks! My wife and I love it too.
I have thought about it but not sure what the center vent attachment is like to that piece. I want to say it's not round so I'll have to play with that. I actually relocated the bracket closer in already. It does in fact have nuts on the end of those bolts. It's something crazy small like a 5.5mm lol
The oil change I did was the first time it's been changed under my ownership. Filter is gone so I will have to check that next time. It was approx 7k miles I think. I'll be changing it every year or 5k from now on.
Instagram: @pdklol
Old 06-07-2019, 04:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
jackb911's Avatar
Hi, Will, GREAT job on the electric A/C install. And that pic of you looking very happy in the car is suitable for framing. That should be on the cover of Excellence!
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 06-07-2019, 04:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Thanks Jack!
Instagram: @pdklol
Old 06-07-2019, 12:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
Been a little while since I've had time to tinker with the car. She needed a battery and I honestly think this has been a large part of why I've been struggling with the AC and keeping the voltage up. No messing around; I went with an Interstate AGM H8. Thing barely fit! I also attacked the UV and heat today and had Xpel Prime Plus 70% tint put on all the glass. It's a nano ceramic IR film. This should help keep the heat down and UV off the interior and my white Irish skin. Hoping the combination of these two items will make a big difference with the AC.
Tint drying in the sun this morning
Instagram: @pdklol
Old 07-09-2019, 07:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
scumbag
Just the right amount of tint. I like it alot.
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
IG: @doktor_b
Old 07-09-2019, 07:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Banned but not out, yet..
RSBob's Avatar
The oil drain plug looks a tad suspicious but not enough to freak over. Change the oil in 3000 miles and check again to see if there is more, less or none.
Beautiful ride.
82SC Made of matter, but not that much
Check out my books on Amazon: Under Big Sky, and Achieving Lasting Happiness
Old 07-09-2019, 07:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Thanks man. drove the car today and loving it so far. Need a sunny day to test it's heat rejection.
Beautiful ride.
Thanks! Will do!
Instagram: @pdklol
Old 07-10-2019, 10:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
