-   -   Help with mixture adjustment CIS (http://forums.pelicanparts.com/porsche-911-technical-forum/100380-help-mixture-adjustment-cis.html)
bob hodges 03-02-2003 06:53 PM
I have searched the past threads and yes I have a 3mm allen wrench to adjust the fuel/air mixture. I only have one question ....where is the adjust screw. I have all kinds of diagrams but could someone that has the engine out take a picture of that screw?
walt 03-02-2003 07:33 PM
There is a small hole right between the fuel distributor and the intake boot. The allen key will need to drop down about 1/2" before it engages in the screw. It's easier to access if you remove the filter cover.
Jbabic 03-02-2003 07:35 PM
I would recommend a CO analyzer or your just going to be guessing....
bob hodges 03-02-2003 08:16 PM
I found it and I thought it was the hole but I know I need a longer wrench. Thanks again...
