what year, motor... has the 36mm intake gasket
I am chasing problems on the race car
decided to pull the carbs and manifolds.
this motor is a combo of different parts and the heads are worked over
the gasket between the head and manifold measure as 36mm
what year and type (T/E/S) of head uses the 36mm intake gasket?
thanks in advance!
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-02-2018, 07:18 AM
just to clarify...
this is the gasket between the head and intake manifold
and the ones I took off have the injector notch in the gasket... even though I run carbs and the heads are not drilled for injectors.
I'm guess it might be the gasket for the 1970 ? (due to the injector notch)
Pelican does not list the ID on that year gasket so I haven't been able to verify.
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-02-2018, 07:43 AM
Under the radar
Trackrash's Avatar
The S models had a 36mm intake manifold gasket.
The Ts and Es had 32mm intake ports.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-02-2018, 10:15 AM
Gordon,
Awesome
thank you so much for your input
and just to clarify....
so a 1970 2.2 S would be the correct 36mm then?
If so, I will get them ordered today !
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-02-2018, 11:40 AM
Help.....
I still need to know what year and model had the 36mm
pelican salesman can only find me a 37mm, and they don't have the ability to find it unless I have a part number.
can anyone confirm that the 1970 2.2 "S" is the correct one and would measure 36mm?
I need to order 18 of these asap for a race......
2 days so far trying to find this part number and getting nervous
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-02-2018, 01:16 PM
Buy the smaller ones, set them on the head and carve them out with a sharp knife.
206 637 4071
Old 08-02-2018, 01:32 PM
Under the radar
Trackrash's Avatar
I've done that ^. A PIA IMO.
Yes, 2,2 S had 36mm intake ports.
Gordon
Old 08-02-2018, 03:09 PM
gearhead
Originally Posted by Brant View Post
Help.....
brant
I believe 69 S was the first 36mm intake port engine, but 70/71 2.2S also got it.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-02-2018, 04:07 PM
Yup, 5 minutes of PIA.
206 637 4071
Old 08-02-2018, 04:15 PM
