Send a message via AIM to 82SC
930 brake application
just some morning musings...
I have a complete 930 brake setup ready to go on a SC...
I am building a targa that will be at minimum a high CR 2.4L 911S or up to a 3.0L MFI RS...with SC suspension
I was planning on saving the 930's for when I build a track car...but would they be overkill on the targa? I was originally planning on using SC brakes on the targa...
I will probably use the targa at DE events...not a hard core track car...hmmm
MJ
Old 03-03-2003, 09:53 AM
hmmm still musing...I hate to have the 930s sit around collecting dust...and I'd hate to sell since they are hard to find at a reasonable price....
HMMMMMmmmmmmmmm....
Old 03-03-2003, 12:14 PM
Bill Verburg's Avatar
Since no permanant changes are needed to the chassis(assuming that the rear calipers were modified to fit SC trailing arms) why not use the 930 brakes now. The boosted m/c will work fine. If you want to use them on something else later swap them out at that time, its not a big deal.
The gray area where bigger brakes are worth it is right in the SC hp & weight region, under not worth it, over worth it. Sometimes ducts pads, fluid is enough sometimes not depends on the driver, frequency and tracks.
Bill Verburg
Old 03-03-2003, 12:25 PM
ahhh...bill the brake guru...hmmm good idea...maybe I can get the targa todo a forward wheelie with the giant 930 calipers...
Old 03-03-2003, 12:29 PM
Since you obviously don't want the brakes to go to waste sitting around gathering dust, give them to me. I can use the extra stopping power now. If you want I'll even put a little "donated by" plaque on the calipers.
A famous little saying comes to mind, "From each according to his means, to each according to his needs."
Old 03-03-2003, 12:34 PM
how about a lease program?? haha
Old 03-03-2003, 12:36 PM
Call Doug at VCI, He is always looking for a set if you don't want them!
Old 03-03-2003, 02:18 PM
