Did pressure test, feedback appreciated (Tony?)
Cold start - Car starts up fine although idle at start up is only around 1200 rpm after about 10 secs.
During course of warming up, when say coming to a stop and engaging clutch, rpm's will drop momentarily to about 300 rpm - almost stalling - then recovers to about 850 rpm. Once engine is warm, all is good - rpm's stay at about 900 rpm, with no near-stall issues. Warm start - no issues. The car : '79 SC (USA) Original 3.0 with WUR ending 045 74 degf WUR ohms : 26.3 Test results : System pressure: 4.9 bar Cold pressure : 2.1 bar WUR Power connected 30 secs : 2.2 bar 60 secs : 2.45 bar 90 secs : 2.7 bar 120 secs : 2.8 bar 150 secs : 2.95 bar 180 secs : 3.03 bar (3.03 - not 3.3) 210 secs : 3.1 bar 240 secs : 3.1 bar 270 secs : 3.13 bar 300 secs : 3.18 bar Residual pressure : 1 min : 2.3 bar 5 mins: 1.8 bar 15 mins : 1.55 bar 30 mins : 1.4 bar 60 mins : 1.2 bar Does the above suggest an out-of-tune WUR? Thanks Jason
'79 911SC Targa |
Fleabit peanut monkey
I dug this out of an old post. The title of the pic is euro CIS. I see your's is a US model but I do not know if they had separate Euro and US WUR's both numbered 045. Kind of doubt it.
1981 911SC Targa |
Thanks Bob.
So system pressure is good at 4.9 my cold pressure is on the low point but within spec. at 2.1 Leak test is good - 1.4 after 30 mins Not sure about the warm test - what determines if vacuum is present? regardless it would appear to be below normal range. Any thoughts? Jason
'79 911SC Targa |
Fuel pressure test.........
Jason,
Were the data you have for the control fuel pressures taken with the engine running or not? Make another test with just the FP running with a fully charged battery. Post the data and I might be able to interpret your test results. Thanks. Tony. |
Engine was not running - only the FP throughout the testing Thanks Jason
'79 911SC Targa |
Control fuel pressures........
Jason, Use the table posted by Bob K. There are two values you need to know, with and without vacuum applied. Use a hand-held vacuum gauge for the initial and final readings. Since I’ve been calibrating WUR-045’s this week, the values are still fresh in my mind. No vacuum: 39~45 psi. W/ vacuum: 46~52 psi. Sorry, I use psi. unit for my calibration and testing for years and been a habit. I seem to remember psi. values than the bar unit (old habit). Keep us posted. Tony |
unfamiliar with vacuum gauges and how to use them ... how would I do so in this application? Any suggestions for a gauge? If I have only the FP running (not the engine), is vacuum not being applied? How is vacuum applied? - by running the engine? a vacuum pump? If so, again how to use? Ref values, I will express warm pressure test in PSI : WUR Power connected 30 secs : 2.2 bar / 31.9 psi 60 secs : 2.45 bar / 35.5 psi 90 secs : 2.7 bar / 39.2 psi 120 secs : 2.8 bar / 40.6 psi 150 secs : 2.95 bar / 42.9 psi 180 secs : 3.03 bar / 43.9 psi 210 secs : 3.1 bar / 44.97 psi 240 secs : 3.1 bar / 44.97 psi 270 secs : 3.13 bar / 45.5 psi 300 secs : 3.18 bar / 46.12 psi thanks jason
'79 911SC Targa |
you can buy a hand pump at HF or advance., they come as a brake bleed set. nice tool to have. you can also check other CIS components with it.
just post the CCP with and without vacuum and the WCP with and without vacuum. RPM dropping like that is a too rich condition. you also have a thermo time valve. that should open up after about 20 seconds of engine running. with no vac pump here is a way to test it. with the engine warm and running remove the vacuum line to the WUR and see if it has vacuum on it. if you buy the vac pump you can do this with engine off. pull a vac on the TTV, turn key on and you should lose vac after about 20 sec. pull a vac on the WUR and make sure it holds to test diaphragm. not related, I would also pull a vac on the brake line to the booster. that hose can cause air leaks.
^^^ Much appreciated ^^^
Jason
'79 911SC Targa |
Believe they are called Mityvac. It's not a "Harbor Freight" tool if you know what I mean. It is a decent quality assembly. Pretty much the only brand I see anywhere for sale. $40-ish these days unless you buy online. As soon as I said it's the only brand, I see HF has cheaper ones. Spend the extra $15 and get the Mityvac. Mine is beat to hell and 15 years old. Still carrying the torch. The scale is Hg on the mityvac. You can go to a conversion website and convert the factory scale to Hg. https://www.harborfreight.com/mityvac-vacuum-pump-39522.html
1981 911SC Targa |
Ok, have a "Mityvac" - now what do I do?
So I bought a Mityvac, now I have no clue what to do with it.
Can someone hold my hand? Thanks Jason
'79 911SC Targa |
Looks like a guide is enclosed. It is slightly different to mine - but basically it should have a switching mechanism that allows it to pressurise, or evacuate the system. In your case you want the vacuum function. Your gauge should be a + and - gauge - above/below ambient pressure. You want to pull around 0.5-0.7 bar to replicate idle vac. This will fit on to your WUR at the port hooked up to the Throttle body port - once you find some appropriate plastic hose bits. The trigger handle does the pump +/- work.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
it only pulls a vacuum. wish I could find something small to pressurize, like my WUR for boost CP.
anyway, just play with it. connect it to the WUR and pull a vac and see if it holds. you would be surprised, I use mine quite a bit.
Thanks.
So if I have this right, I am going to re-run the warm pressure test (power to the WUR) with vacuum to the WUR port and note pressure values every 30 secs upto say 5 mins? Jason
'79 911SC Targa |
Open the package, put your wet finger over the snoot and pull the lever. You will feel a vacuum on your finger tip. Put a rubber hose on the snoot and the other end on the WUR where you pull the vacuum line off. Create the vacuum inside the WUR for testing. Observe if there is change in the warm control pressure with test vacuum applied AFTER you reach that max BAR setting of 3.18.
Your mityvac scale is in inHG (inches of mercury). You need to convert the factory specs in millimeters of mercury to inches of mercury. 350-450 mmHG is 13.8 - 17.7 inches of mercury. Pretty much high noon on your mityvac scale if you take it to 15 inHG. Did you confirm vacuum at the line going into WUR as T77 suggested?
1981 911SC Targa |
Will report back in due course Many thanks Jason
'79 911SC Targa |
The test of the vacuum line going in is an engine running test. More of is there vacuum when you are running. This is a little separate from the engine not running test for WCP.
Let's say you are cruising at 35, nice and steady. You will have plenty of vacuum in the intake because the throttle plate is open just a little. Your WCP should be above that 3.18 bar because the vacuum is sucking on the diaphragm in the WUR. Let's say 3.5 for discussion. More lean for emission purposes. Push the pedal to the floor and you open the throttle plate allowing lots more air in reducing intake vacuum. Suction on the diaphragm goes away and WCP drops to the 3.18 bar number. More rich for performance. Let off the gas WCP leans out. You need to know two things. Is vacuum with engine running getting to the WUR through the hose? If you have vacuum through the hose, does the WUR hold the vacuum? The latter is the static test with the mityvac. Former is engine running. Put your finger on the end of the hose and check. Edit: To answer the question of pulling vacuum throughout the test it is not necessary. Warm control pressure is what you essentially achieve after cold control pressure has gone through it's warm up cycle.
1981 911SC Targa Last edited by Bob Kontak; 07-12-2018 at 07:03 AM.. |
1) - checking if the WUR holds vacuum by applying suction to the WUR using the Mityvac, with about .5 bar, engine not running 2) - with engine running, check if there is any suction on the vacuum hose which leads into the WUR 3) - with engine running, do pressure test Will report back Many thanks jason
'79 911SC Targa |
+1
Pressure test with engine on and off just to see if there is a difference. Hit it with suction post warm up to check if pressure goes in the right direction and does not exceed the max WCP as stated in the graph. Hoping all will be well. I would not sweat the 0.08 WCP higher than spec w/o vacuum. However, if you want more gas under full throttle send the WUR to Tony and he can adjust. Doubt you would notice a difference.
1981 911SC Targa Last edited by Bob Kontak; 07-12-2018 at 11:17 AM.. |
Invaluable. Alan
