-   -   Differences in SSI models (http://forums.pelicanparts.com/porsche-911-technical-forum/1004389-differences-ssi-models.html)
sigchuck 08-08-2018 07:26 AM
Hi guys, I have an '83 SC that I am in search of gently used SSIs for. I know for an '83 I would typically use the "thick flange" model.
I noticed SSI makes thick flange exchangers for the '80-'83 3.0 and, under a separate model number, for the '84-'89 3.2. The flange thickness on both models is apparently the same.
My question is are these parts interchangeable? Can I use the 3.2 exchangers on my '83 3.0?
Thanks in advance!
pampadori 08-08-2018 11:49 AM
I thought I'd read that the pipe diameter is larger for the 3.2 SSI's. THen i also thought that I had read Dansk was no longer making both models.
Flat6pac 08-08-2018 12:26 PM
The insert into the heads would be larger on the carrera boxes.
The C2 boxes are thick flange but no inserts.
Bruce
