Assembling Euro H4's
Just bought a set of euro H4's from local porsche guy.
They came brand new in boxes but aren't assembled. I have sugar scoops on my 911sc so I can't really compare them to see how to assemble the euro H4's.
Does anyone have a closeup pick of their H4? Where do the "7" clips go? Between the reflector and trim ring?
What do these screws do?
Old 11-06-2017, 02:27 AM
Flojo's Avatar
the screw is the final one to fix the headlamp when set in socket.
sits at bottom, through ring.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-06-2017, 02:48 AM
Am i missing any parts? The picture you posted looks like i dont have #2. I assume #8 and #8A are the same?
Old 11-06-2017, 03:24 AM
Flojo's Avatar
#2 is the seal between fender and headlamp (#3 is the seal from glass to head lamp frame).
8A is a paint ring you can place over #8, so just ignore it
Old 11-06-2017, 04:07 AM
Goth's Avatar
8 would be the chrome ring.
8a is the optional painted cover ring.
The lens uses a gasket. So I'm guessing thats what 2 is.
Old 11-06-2017, 04:15 AM
Ahh gotcha. That makes sense now.
Thanks alot for the help.
Any zoom in pictures on the clips? The ones that look like a "7"?
After that i should be good to piece them together
Old 11-06-2017, 04:16 AM
This is all quite interesting as I also have H4's in my sc. What I'm concerned with is what's involved in replacing the bulbs. Does the complete bucket assembly have to be removed to replace the bulb?
Old 11-06-2017, 05:15 AM
Yes
Old 11-06-2017, 05:37 AM
Flojo's Avatar
these spring brackets clip in quite logically and only one way. when setting in place they do overlap each other a little. they maintain the outir ring to the frame.
read this?
http://www.pelicanparts.com/techarticles/mult_h4_headlamps/mult_h4_headlamps.htm
Old 11-06-2017, 05:45 AM
Formerly known as Syzygy
Canada Kev's Avatar
Yes, the light assembly has to be removed from the fender as there is no access from behind. However, once the light is out, it's just the single clip in the back that must be opened to remove the bulb and then re-installing the light using the single screw at the bottom to secure it.
Kevin
Old 11-06-2017, 06:05 AM
Undocumented User
McLaren-TAG's Avatar
Hard to tell from your picture but it looks like you may be missing the adjustment tabs. the long machine screws have this 90 degree tab looking thing that then inserts into a rubber grommet so you can adjust the floating bucket from the inside in the vertical and horizontal axis. Anyone like my that's done it a few time can do it in their sleep but it's much easier to show than to explain. I take mine out twice a year since I insist on having yellow lenses that won't pass inspection, I replace the lenses with clear ones to get the sticker every year.
Old 11-06-2017, 06:21 AM
Thanks Kevin, so if I understand correctly there is only the one screw at the bottom of the ring that has to be removed in order to remove the headlight bucket. Is that correct?
Old 11-06-2017, 07:41 AM
Flojo's Avatar
yes.
at top it is hooked on a lip lurking from the fender
Old 11-06-2017, 07:51 AM
Canada Kev's Avatar
If the rings around your lights are panted body colour, those are probably just the painted trim rings which are still held on by that screw at the bottom. So don't be surprised when that ring separates from the headlight when you go to remove them.
The aiming screws are also hidden under that cover.
Kevin
Old 11-06-2017, 08:14 AM
Hugh — be sure to read up on issues folks have had when installing these headlight assemblies for the first time, can be a challenge to get the assembly secured onto the top rim AND screwed in properly on the bottom - some have even found themselves driving over their lights after hitting a bump. Fwiw
Old 11-06-2017, 08:37 AM
Thank you Darren. My SC came equipped with H4's and I'm hopping to upgrade to 100/80 watt bulbs once I complete the added relays needed to lighten to load on the switch gear and I wanted to be sure how to go about replacing the bulbs.
Old 11-06-2017, 12:19 PM
Oops - didn’t notice that u weren’t the op - 100/80 bulbs with relays are a nice upgrade
Old 11-06-2017, 12:37 PM
Here some pictures, I hope those help to assemble your headlights.
From your picture I assume you have most of the parts.
I do not see three rubber tubings that hold the reflector to the grey bucket and the adjusters. Apparently the lens has the rubber gasket. I do not see the rubber gasket that goes between the fender and the headlight.
The screw you show is to hold the headlight to the fender. That screw is used with a small screw to hold a trim ring that goes outside of the chrome ring, you do not have that trim ring. The last pictures show that trim ring and the small screw.
Old 11-06-2017, 06:24 PM
Old 11-06-2017, 06:26 PM
The gasket I show is for the lens.
Old 11-06-2017, 07:19 PM
