Help identifying two pin plug under the dash
sorting some wiring under the dash on my 76 912E... I think i have it all figured out except for this random plug.... any ideas?
http://forums.pelicanparts.com/uploa...1533692550.jpg http://forums.pelicanparts.com/uploa...1533692550.jpg |
Yup, that’s the plug to hook up the annoying buzzer that goes off when you open the door with key in ignition. You’ll find the spot to connect it on the metal ignition body unit.
You’ll hook it up, try it and then disconnect it again! |
thank you so much! that will be getting zip tied neatly up under the dash!
| All times are GMT -8. The time now is 10:19 PM. |
