-   -   1977 2.7 CIS - No spark on crank, spark on run (http://forums.pelicanparts.com/porsche-911-technical-forum/1004626-1977-2-7-cis-no-spark-crank-spark-run.html)
maninblack 08-10-2018 04:07 PM
Trying to track down an issue on my '77 911. Car was running and driving when I bought it but has been sitting for about a year.
The car has no spark when cranking but does have spark with the key in the run position. Verified by pulling a plug lead to see the spark. When we're cranking, there is no spark at all. But when we stop cranking there is brief spark as the car briefly turns over before stopping with the key in the run position.
Seems like I've read about this issue before. Anyone have any ideas for me?
Knockdown 08-10-2018 04:42 PM
Could be low or no voltage getting to the CDI during cranking, maybe even a low battery.
maninblack 08-10-2018 04:43 PM
Battery fully charged and tested with a second battery.
pa911 08-10-2018 05:40 PM
You should have power going to the center pin on the CDI .if it's a Bosch 3 pin
maninblack 08-10-2018 05:47 PM
Car has a blue Permatune which I believe to be factory (little known fact, Porsche installed Permatune units at the factory on some cars in the 70's). Still a three wire connection. I'll check the power at crank tomorrow.
Any other ideas?
pa911 08-10-2018 05:52 PM
Have you checked the coil?What kind of coil do you have?
maninblack 08-10-2018 05:56 PM
Bosch coil. Assuming coil is good as I have spark with key in the run position.
Walter_Middie 08-11-2018 06:46 AM
maninblack,
When you are running the starter, there is a separate path for +12v to power the ignition. It is the yellow wire attached to the starter. Could yours be unplugged? It also powers the Thermo Time Switch and the Cold Start Valve.
maninblack 08-11-2018 08:42 AM
Got it guys. Break in a wire from battery. Thanks for the help.
rwest 08-11-2018 10:28 AM
Excellent, glad it worked out for you- which cable?
