In fairness the car started out as s 912E. Could possibly change things. |
His posts are both accurate and cautionary. It implies that something may be out of spec on your car. Have you done an alignment prior to fitment? Do both sides measure out the same? BTW, nice looking wheel. |
I will report back when they are on.
Thanks for all the feed back guys it is appreciated. With regard to fitment. My fitment preference is not for track set up. The car will be much lower in stance then typically seen on this form. |
http://forums.pelicanparts.com/uploa...1534102752.jpg Look forward to seeing your progress. |
If that’s the hub to hub width my hub width isn’t anywhere near that narrow. Mine is 56-1/8” hub face to hub face. Both sides have a front hub to inside lip of fender is 2.75”. Everything seems true and straight |
it differs from hub to hub by 2x the wheel offset(ET), 6" Fuchs have ET36, this is positive in nature and so 72mm(~2.8") is added from the track to get the hub separation. |
so for the pictured car if 54.06" is the track 54.06 + 2.83 = 56.89" is the hub width I have amended this and my previous post, a negative o/s wheel will move the track width in while a positive o/s wheel(all Fuchs) move the track width out I n each case by 2xs the ET |
Thanks for all the great info.
What I do know is from my hub face to the inside lip of my none rolled fenders on both sides is 2.75”. And I subtracted 1/4” for clearance. |
positive o/s wheels move the track in by 2x the wheel ET. track - 2xET = hub width for 6" Fuchs w/ ET36 in the above diagram 54.06" - 2x36mm 54.06" - 72mm 54.06" - 2.83" 51.23" is the hub width |
Bill, i think your other measurements were correct. The WMS sits closer to the outside of the wheel on a positive offset wheel leaving the wheel centerline (track) inboard of the WMS. The hub to hub width is wider than the track width. .. |
positive ET wheels move the center line in from the hub so the wheel ET x2 need to be added to the track ti get the hub width. |
I hope it was a good bottle of wine. |
I'm confidant in the setup I wanted and what we measured too. If I was building a traditional car and setup I would be worried. However considering my car is VERY FAR from traditional I believe the way I had them built will more then satisfy me liking. Again thanks . Now I am going to wait patiently at the door for the mail man for my new wheels. :D |
Arrived and test fired. Absolutely nailed it and what I wanted. No way I could be anymore happy. :D:D:D
http://forums.pelicanparts.com/uploa...1534528691.jpg http://forums.pelicanparts.com/uploa...1534528691.jpg http://forums.pelicanparts.com/uploa...1534528833.jpg http://forums.pelicanparts.com/uploa...1534528833.jpg http://forums.pelicanparts.com/uploa...1534529061.jpg http://forums.pelicanparts.com/uploa...1534529061.jpg http://forums.pelicanparts.com/uploa...1534529061.jpg |
I think those look FANTASTIC! Looking forward to seeing them with tires and mounted.
Great job Jeremy
| All times are GMT -8. The time now is 03:19 PM. |
