Mono ball front strut mounts
Are solid strut mounts to hard for Street use? Should I go with ER rubber upper strut mounts.
Would have said mono's on the front struts are more about precision geometry than ride comfort. In my experience, the shock set-up, ride height and torsion bars will have more effect on the ride quality, than swapping out traditional donut strut mounts for monoballs.
Don't buy a Porsche until you can afford two. 1980 SC - sold 1983 SC - sold 2000 C4 - sold 1967 912.5 in DIY build |
I'm running Bilstein sports on all four. 23/31 Saunders solid torsion bars and Euro height.
I had a slightly softer set up than you are running and when I added them I did not notice a change in harshness.....it was pretty firm already.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Good to know. Thanks
My car weighs 2600 lbs.
Are you considering only Elephant Racing products or are you also looking at Rebel Racing? I am going through a similar evaluation process - looking at RSR Semi-solids as well - please let me know what you decide.
El Duderino
I went with ER rubber. I think Craig_D's suspension thread discussed this. IIRC, he tried the monoball and they were too harsh for street use. Harshness is subjective.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
I run the weltmeister monoball camber plates up front, bilstein sports, 19mm raised struts, it's not too harsh for street driving for me.
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
If I go with solid monoball. I will use Rebel Racing. If i go with Rubber. It will be ER. Trying to get some more advise from fellow pelicans. I dont mind a hard ride for street. Not a daily driver. Going to be a canyon carver and some AX.
JMHO,
Street cars get rubber, race cars get monoballs. This makes & retains happy customers.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I have the ER monoballs. Not more harsh ride, but my car has no rubber components otherwise anyway, so it was already harsh. Certainly a little more high frequency road vibration but after a few days that feels normal.
If I would do it again, it would not get the monoballs only, but rather the adjustable camber plates which itself have monoballs, at least the ER ones. |
On my '88 I started from the original stock rubber strut mounts as well as the entire front suspension. Installed Rebel A-arm hard bushings, 22mm torsion bars, turbo tie-rods, custom valved Bilstein sports for the 22's and capped it off with Elephant strut mount camber plates w/monoball built in.
Of course the TBs made the ride stiffer but the combination of all elements have made the suspension way smoother and LESS jolting. You can actually feel the suspension "move" and react to bumps instead of the jolt I used to get. I agree with Horst that on high frequency road surfaces there prob is some vibration that rubber might isolate. According to Elephant and my local P-car race shop, the mono-ball camber plates allow you to get a little more negative camber then the stock rubber ones. You can always sell them for prob 70% of value if you feel like they make a negative impact. Now the Rebel rear polyurethane engine mounts I just installed made a very noticeable difference in high frequency vibration in the rear, not bad but noticeable.
______________ '88 911 Coupe '98 Spec Boxster '85 380SL Benz -Euro |
/\ that is exactly right. I had the Poly Bronze bushings, turbo tie rods, T bars, Konis and monoball strut tops. Once I got the alignment and corner weight right the suspension was so supple and you could feel it moving and what it was doing. It was harsh in some situations.
I'm re-doing my suspension this winter, and just tore off the front suspension. I have ER mono balls for the front I plan on installing as well as planning Rebel racing bushings front and rear along with ER rear mono balls. Hoping its not too harsh! Guess I'll have to report back in the spring! But like others said.. it's subjective. Hopefully I'll be on the side of enjoyment rather than annoyance.
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
I don't think it's really worth fretting that hard over. I run the eBay spherical plates, and had one of the cheapie bearings die on me pretty quickly. I swapped the OE ones back in while I repaired them, and didn't notice much of a ride or performance difference, even after swapping back to back, in competition autocross use. I for sure can get more camber with the aftermarket bits, but that's it.
For a street car, on street tires, I wouldn't even bother touching the factory stuff unless it's falling apart. The OE part is durable and well designed, and there's not all that much compliance in that area. Full race car on R-comps hunting down a final 1/10th of a second? Then yes, maybe worth it. Bigger fish to fry up front is hunting down and eliminating as much bind as possible in the a-arms and swaybar. If you MUST buy fancy monoballs, I doubt you'll regret that either. They won't suddenly transform your car in any way whatsoever, neither good nor bad. Small difference. IMHO, YMMV, and all that jazz.
Matt - 84 Carrera Last edited by Driven97; 12-22-2015 at 05:00 AM.. |
Yeah I wonder if old rubber a arm bushings combined with the stock front sway bar set up are really messing up the ride on a lot of cars because of binding and a compromise design.
Cars Ruined My Life
I just did Konis all around, polybronze ER and ER rubber top mounts.
Monoballs for race cars Sent from my iPhone using Tapatalk |
Sage advise from someone who's been there, done that, many, many times.
Jon |
