-   -   19mm Rear sway round clear bushing install tips? (http://forums.pelicanparts.com/porsche-911-technical-forum/1004892-19mm-rear-sway-round-clear-bushing-install-tips.html)
ARCSinAK 08-13-2018 11:08 PM
Tried lubing the clear bushing up and using a C clamp but seemed like I was deforming/smashing the bushing. Any advice on this step of the instal?http://forums.pelicanparts.com/uploa...1534226823.jpg
Knockdown 08-14-2018 05:07 AM
Used a pair of channel lock pliers to get the bushing into the drop link, C clamp to install onto the ball.
bkreigsr 08-14-2018 10:16 AM
Here's how I do it.
Use a vise to press the grommet into the link. (help the edges with a screwdriver)
Do a false install and align the grommet to the ball in the swing arm.
Prop up the sway bar to the height of the ball.
Cut a broom/mop handle to somewhere around 13 inches.
Align the broom handle with the grommet and give it a few good whacks with a 3 pound hammer.
If it's the first time install for the grommet - it's going to take some extra effort, but it will go in.
Bill K
ARCSinAK 08-14-2018 10:24 AM
Sure appreciate the tips. Going to weld on the brackets this AM.
911pcars 08-14-2018 12:17 PM
Not unlike installing the support bushing at the front end of the shift tube.
Clamp the drop link in a bench vise, then use large “Channel Lock” pliers to squeeze it into place. Heating it in hot water should also make it more pliable.
Sherwood
