Jameel's Avatar
Plugged front condenser blower holes
Spent a couple hours the other morning with my brother removing the front AC condenser and plugging the resultant holes in his car. The AC in this car was partially removed last year, so we're just finishing up the process. Here's what we came up with.
The hole on the floor was the easy one. Ran some new weather stripping around the opening and painted up a 22 gauge piece of steel to cover the hole. Nothing complex here.
The hole in the front bulkhead was another story. We couldn't quite figure out the best way to seal this off. We eventually decided to fab a piece of steel that matched the profile of the grommet, then attach it with a clamp arrangement, the same way the torsion bar access covers attach to the rocker panels. The clamp is 1/8" thick steel and uses a 6mm bolt press fit into the clamp. The piece was a little tricky to bend since the step is larger on one side of the hole, but it was pretty simple actually. For a good seal we kept the grommet in place. This area sees some wetness in the rain, its right behind the gap between the bumper and valence. Because we couldn't put a lot of torque on the nut (due to the compression of the grommet) we simply added another nut as a stop nut.
It's really clean up there now, and with the condenser fan gone, there's room for a 944 jack to reside. If we ever want to put the AC back, these will come off in less than a minute.
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 01-15-2018, 06:53 AM
Uncertifiable!!!
Uwon's Avatar
Nicely done!
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-16-2018, 04:51 AM
wow - quality job.
Old 03-13-2018, 07:29 AM
Dr J's Avatar
Very nice.
Quick question. Does this not pressurize the frunk as the air rammed in has nowhere to go and result in gages popping out?
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 12-17-2018, 03:00 PM
Not on mine. The forward intake hole is behind the bumper and doesn't get ram air. I covered the bottom outlet hole but left the front inlet hole open (for now).
Old 12-17-2018, 05:20 PM
I did the same for the bottom hole but haven't attempted the upper hole. BTW you can disassemble the washer pump and clean out all the green. It can be restored to work and look like new. My washer pump looked as green as yours.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 12-17-2018, 05:33 PM
