3.2 Oil leak
Any thoughts on where this leak is originating? '86 3.2 Doesn't seem to be coming from above but from the port. Hopefully there is a pic attached. Thanks
Old 08-16-2018, 07:23 AM
Should have mentioned that this is located at front right cylinder. Thanks
Old 08-16-2018, 07:25 AM
Looks like the compound used to seal the heads to cam carrier is breaking down or
You have a rocker shaft moving off location.
Bruce
Old 08-16-2018, 08:55 AM
Thanks for the response. It was not a leak that I've seen as typical of many discussed here I so was concerned. Are there any immediate repercussions I need to
be aware of? It's been this way for a while and gradually gotten worse.
Thanks.
Old 08-16-2018, 02:17 PM
