3.2 Fuel Line Removal
So I am in the process of removing the fuel lines on my 3.2. I got the SS Braided lines from Len which look great.
I am trying to remove them without removing the intake runners. I have everything off including the Allan bolt in the middle of the T.
How ever I am stuck trying to get the bracket in the far left corner removed? I can see the bolt from the front but don't seem to have any access to the back of it. and have tried every possible combination of sockets and wrenches but there doesn't seem to be enough room to get to it. As it seems like the other fuel lines and fuel pressure regulator are in the way.
Any suggestions?
Old 08-18-2018, 01:14 PM
I believe that this is the bolt that needs to be removed but just can't seem to get a wrench on it
Old 08-18-2018, 01:41 PM
That Guy
Techno Duck's Avatar
Two bolts accessible from above the valve cover.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-18-2018, 02:48 PM
Thanks, Do I need to remove those bolts and the whole fuel pressure regulator assembly? or should i be able to undo the bracket without taking all of that apart?
This is the bracket that i need to get undone
Old 08-18-2018, 02:55 PM
steely's Avatar
If you are just removing that 'T', I think you only need to remove the bolt circled in your pic of post #2, the bracket doesn't have to come out. I did this 10 years ago so my memory may be off, and I also need to mention that I was intending to remove the intakes - so my process/order may have incorrect as this was my very first project.
The one that I had the most problems with was the 4mm? x long socket head cap screw that you mentioned.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 08-18-2018, 04:39 PM
