carlos's Avatar
no start blues
Hello All,
My 75 911/930 has developed an attitude. Not just when I gas it either! Lately when I turn the key it doesn't want to start. Nothing, all lights and fuel pump go but no start. Then it'll fire right up. Should I look at some connections before I replace the ignition swith?
Also, my car only gets 10 miles per gallon when I drive it hard. Should I be getting more, or do i maybe have a problem?
3.0 w/rayjay turbo setup.
Thanks for your help!!
Carlos (fastlos)
75 911/930 Turbo
68 AMX 390
95 trooper
86 930 Powerhaus Stage 1 W/SC Cams Billstein Sports Weltmeister Torsion Bars & Strut tower brace Kinesis 9 & 11 K-28's Lowered Balanced "Scary Fast"
87 BMW 735I "Kid & Grocery Hauler"
*68 AMX 390 Go Pack
4-Speed "Burnout King"
*82 Honda Trail 70 "Just Fun"
*Future Cart Champion Son, Mateo "Go Da Da Posha Go Trbo"
Old 03-05-2003, 01:19 PM
Friend of Warren
Check connections on battery (both pos. and neg.) connections on starter, ground strap from transmission mount to body and make sure the plug on the back of the ignition switch is clean and pushed all the way in. If all those are good then probably bad ignition switch.
Kurt V
Old 03-05-2003, 02:15 PM
