-   -   Rough idle (http://forums.pelicanparts.com/porsche-911-technical-forum/10055-rough-idle.html)
ZE911 11-07-2001 10:17 AM
Rough idle
Another bonehead mistake. Car was running alittle rough at idle. After 15 seconds of investigation discovered the oil cap was gone. It's probably sitting on top of a Chevron gas pump 50 miles away. Does the oil need to be changed immediately?
Jim Sims 11-07-2001 10:27 AM
Many have done this or not had the cap on correctly. Look down around the rubber engine sealing flap; the cap may be there. Unless it was really dusty I doubt you pulled much dust through into the oil but on the other hand oil and oil filters are pretty cheap and if you're near the end of a change interval I'd put new oil in this weekend. Jim
wckrause 11-07-2001 10:27 AM
I can't see why you'd need to change the oil any sooner.
Bill Krause
'79 911SC Euro
MY PELICAN GALLERY
makaio 11-07-2001 11:12 AM
I did the same thing the night I was driving my car home from purchase. what I do to make sure I don't loose the cap in the future is place it on the right rear engine mount. That way if I forget to put it back on, at least it is still there when I remeber.
I would go ahead and change the oil and filter, cheap insurance.
Matt Chamblin
78 911 SC
ZE911 11-07-2001 10:06 PM
Thanks for the reply. Looked around the engine bay, cap is history. A new one is on it's way. Probably should have ordered two.
