Red face Rough idle
Another bonehead mistake. Car was running alittle rough at idle. After 15 seconds of investigation discovered the oil cap was gone. It's probably sitting on top of a Chevron gas pump 50 miles away. Does the oil need to be changed immediately?
Old 11-07-2001, 10:17 AM
Post
Many have done this or not had the cap on correctly. Look down around the rubber engine sealing flap; the cap may be there. Unless it was really dusty I doubt you pulled much dust through into the oil but on the other hand oil and oil filters are pretty cheap and if you're near the end of a change interval I'd put new oil in this weekend. Jim
Old 11-07-2001, 10:27 AM
wckrause's Avatar
Post
I can't see why you'd need to change the oil any sooner.
Bill Krause
'79 911SC Euro
MY PELICAN GALLERY
makaio's Avatar
Post
I did the same thing the night I was driving my car home from purchase. what I do to make sure I don't loose the cap in the future is place it on the right rear engine mount. That way if I forget to put it back on, at least it is still there when I remeber.
I would go ahead and change the oil and filter, cheap insurance.
Matt Chamblin
78 911 SC
Old 11-07-2001, 11:12 AM
Talking
Thanks for the reply. Looked around the engine bay, cap is history. A new one is on it's way. Probably should have ordered two.
Old 11-07-2001, 10:06 PM
