Question Koni Question
Are the rear Koni shocks adjustable as are the fronts?
The PO had Konis Sports shocks installed and I've had no problem with adjustment on the front. just wondering about the rears
If so, how do you do it?
thx,
todd
86 cpe
Old 03-04-2003, 08:41 AM
Tim L's Avatar
The ones I have are. You have to remove the shocks to set them.
Tim
Old 03-04-2003, 08:58 AM
koni usa is prompt to ansewer my questions. get your id number and send them an e-mail
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-04-2003, 09:52 AM
Hilbilly Deluxe
emcon5's Avatar
Tim
Ok, I don't have Koni's but this has me curious. How do you set them?
My old (dearly departed) SVO Mustang had Koni shocks, the rears were adjusted by unbolting the lower mount and compressing the shock. Apparently some teeth on one end would engage an adjusting wheel at the other, and you rotated the bottom to turn the wheel and change the settings.
Is it still like this, or are the 911 Koni's different?
Tom
82 911SC Coupe
GTI Cup #43
Old 03-04-2003, 10:04 AM
I believe the gas charged versions are like this where you need to remove one mounting bolt....look for another thread like this where I go into more detail...
I have hydraulic rears that are top-side adjustable via the small white removable knob like the gas charged fronts. nice.
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-04-2003, 10:16 AM
Tim L's Avatar
The ones I have you need to remove the shield then depress a button and turn the shaft. I think it has 4 or 5 detents where you can stop the rotation at the desired stiffness.
Tim
Old 03-04-2003, 10:51 AM
Hilbilly Deluxe
emcon5's Avatar
Kind of funny, I was looking through the archives on a completely unrelated topic, and came across this picture:
Looks like the directions are on the shock.
Tom
82 911SC Coupe
GTI Cup #43
Old 03-04-2003, 01:54 PM
Cool! I'll have to get under there this weekend (while I'm already under there already for fixing a heater cable). Maybe there is some info on the Koni web site. I'll have to check that out this eve after wk.
If the PO set the rears as the fronts were on my car when I got it (max damp) I should be looking at a more compliant ride next week.
thx,
todd
86 cpe
Old 03-04-2003, 02:14 PM
