Throttle spring from linkage to runner 2 question
So my CIS throttle spring vanished (flew off of runner 2) and I could not see where
on the throttle linkage it attached. Does it go in the green square and then to the runner? How long is the unstretched spring I'm hunting? http://forums.pelicanparts.com/uploa...1535068348.jpg |
It goes thru the little pin hole to the left, look straight back and you should see where the other end will hook on to with same sized hole on the intake manifold
On the right of this pic, about yea long.
911.110.165.02 http://forums.pelicanparts.com/uploa...1452112673.jpg |
Well sorry about taking so long to thank you gents! I guess I got caught up in the solution.
Thanks for the information |
| All times are GMT -8. The time now is 11:04 AM. |
