-   -   Trailing arm Bearings vs. stock bushing (http://forums.pelicanparts.com/porsche-911-technical-forum/100586-trailing-arm-bearings-vs-stock-bushing.html)
scca_ita 03-04-2003 07:31 AM
I am going to coil overs and for the rear trailing arms I was considering replacing the rubber bushing with bearings.
I also will use a new 935 spring plate.
Is this over kill for a car which is dual purpose track/street?
Chuck Moreland 03-04-2003 08:38 AM
IMHO, inner trailing arm monoball bearings are a no-brainer with your setup.
Coils and 935 spring plates is a serious setup. To pair that with rubber bushings doesn't make a lot of sense. Sorta like skipping to the advance stuff without covering the basics.
