Targa_PB_78_SC
mike sampsel's Avatar
Throttle body vacuum lines and empty nipple
So I've got two "skinny" vacuum lines off the throttle body, red one to the dizzy (I think) and one to the smog pump (yellow one) pump is not operational per my wrench.
Does the red one towards the front of the car go to the dizzy? Pretty sure it does but I miss labeled it somehow AAR doh ...
Then there is the nipple with no connection (green one). Is this normal for a non-CA '79 SC?
Old 08-25-2018, 09:05 AM
The front one, red, would be the vacuum advance for the distributor at high RPM.
The one to the rear, green, is vacuum at idle
you have vacuum needed for the pod between #2 and3 runner and electrical connector.
Bruce
Old 08-25-2018, 09:54 AM
Targa_PB_78_SC
Bruce
So the dizzy only has one connector? Vacuum at idle connects how?
The pod is the WUR?
Old 08-25-2018, 10:31 AM
The pod is on 78/79 has a flat two point electrical connector and a vacuum line under what is the heater blower motor. It’s about a 2 inch disc.
The distributor on 78/79 only vacuum advances at higher RPM. the connection is above the butterfly
The green connector is vacuum at idle, below the butterfly
Bruce
Old 08-25-2018, 10:38 AM
Targa_PB_78_SC
Bruce
So is the “green nipple” vacuum at idle supposed to connect to something?
Old 08-25-2018, 11:19 AM
