Who has shipped a transmission?
I need to ship my 915 for some work but am unsure how to package it and am unsure if FedEx/UPS will be able to ship something this heavy. Any advice? Thank you.
1980 911SC Targa 3.6L |
Here is what I do.
Tru6 Restoration & Design |
The Do Not Tumble signs I stick on are very important. UPS will tumble these off the truck, off anything, and tumble them to move them instead of using a dolly and destroy even a well-built wooden crate.
Wow, that transmission packing job is amazing, Shaun! But, I think this is the way that Shaun packs all of stuff. I had him refinish a fan, housing, valve covers, timing chain covers and some other stuff, and they all arrived superbly packed, in addition to looking beuatiful. Laughingly, many years ago I bought a TR6 transmission from an ebay ad. It arrived strapped to a pallet. No packing whatsoever. The seller even left the shift lever still installed. Amazingly, no damage!
1990 964 Coupe 1986 Carrera 3.2 Targa |
I've used Rubbermaid tubs with high density foam encapsulating the trans and the lid held on with zip ties through holes I drilled around the lid parimeter where it interfaces with the tub. Holds up pretty well.
non-whiner
Get a cheap Walmart plastic cooler and a bunch of cardboard and duct tape. Pack it in the cooler surrounded by cardboard and wrap the whole thing with duct tape and add “this side up” and “do not stack” warnings. You are good to go.
"Too much is just enough." |
The 9 Store
FedEx destroyed a trans I sent in a Rubbermaid tub. Hit it directly with the forklift. Denied my claim. Said it was improperly packed. Now I strap to a pallet and wrap with clear plastic. No issues.
All used parts sold as is. |
I've sent several transmissions - each time I thoroughly strapped it to a wood pallet with come n go's and delivered it to shipper such as Forward Air. I've received them the same way - strapped to pallets and I had to go pick them up. Now these were not Porsche $$,$$$ transmissions but they were not junk either (mostly Audi quattro stuff).
Brandon '91 911 Turbo '87 325i Convertible '16 Audi Allroad Denver, CO |
Stahlwerks.com
I have used Action Packer tubs, bolt the tranny to plywood as other have. Pack with high density foam and bolt the tub closed.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
https://www.fastenal.com/en/22/3pl-(third-party-logistics)
Jeremy Brooks AKA VWLOOSENUTS ***My cars are built to meet my approval, not yours!! My money, my cars, my happiness. |
I've shipped several 915 transmissions. Sometimes the shipper will require you to remove the oil in advance (some consider it a hazardous waste and will charge more). You will find your lowest rates are when you can drop off at a truck distribution center. As in previous posts, I bolted the transmission to a pallet. Depending on the shipper, that might be good enough. Most, however, require you to box it which means building your own box. If you do that, make sure that you put clearance on the bottom for a fork lift. I've paid as little as $300 coast to coast.
Yes, I built a fancy crate. I still strapped it down on a pallet.
gearhead
https://www.amazon.com/gp/aw/d/B01BU5W1IC/ref=mp_s_a_1_1/130-9891514-6361912?ie=UTF8&qid=1524172906&sr=8-1-spons&pi=AC_SX236_SY340_QL65&keywords=instapak+foam&psc=1
A few of these are how you contain a gearbox inside a cooler.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
gearhead
Back in 1988, I hand carried the gearstack of a 901 on a plane... with shafts sticking out the bag. No one said a word. And the case and diff went along with me in a checked large suitcase. Different day...
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
915 boxes fit well into the largest Walmart cooler. then drill and use industrial zipties to secure. Strong, light and if you aren't handy with wood a good trade off of time/cost. I've had a few shipped without issue this route.
A 996tt box is TOO big..... personal experience LOL
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Similar to John Walker's crate:
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
ALSO
FedEx has more options than UPS....though they both have FREIGHT these days.
