-   -   headlights high and low beam mixed (http://forums.pelicanparts.com/porsche-911-technical-forum/1006432-headlights-high-low-beam-mixed.html)
Jvdv23 08-30-2018 11:14 AM
Hello
My Porsche 911SC from 1980 has a wiring issue with the lights. When I put on the lights the high beam goes on. When I push the indicator the blue light on the dash goes on and the regular headlight go on.
Where should I rewire? At the steering wheel, at the fuse box or at the lights themselves??
Thx!
timmy2 08-30-2018 11:41 AM
Was it working normally and this is a new problem?
Look at this thread on turn signal quick fix if it is new.
http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
Jvdv23 08-30-2018 01:42 PM
The problem is there since i own the car. My feeling is the wiring is wrong. The stalk functions ok
timmy2 08-30-2018 03:01 PM
Ok, yellow and white wires at the fuse panel may be mixed up top to bottom.
Take a photo of the first 8 fuses and terminals closest to the front of the car and post it.
Is there a headlight relay mod installed?
RSTarga 08-30-2018 03:32 PM
bad turn signal switch/headlight switch
as Timmy says, install a relay too
timmy2 08-30-2018 03:47 PM
Could be as simple as yellow and white on the wrong terminals at the headlight switch as well.
I am guessing you haven’t had the car a long time.
Edit: looked at your prior posts, 2-3 months of proud ownership. :)
Post some photos of your car if you are home now.
Jvdv23 09-13-2018 01:18 PM
I switched two wires at the headlight itself and it is fixed. Thx!
