1075 cis component
what does item#20 do? This shows it as a component on my 75. My car does not have one and i am wondering what function it performs. Since it is a attached to the throttle i suspect that it increase fuel pressure as the throttle plate opens.
does it help with acceleration or is it a device best left removed? thanks http://forums.pelicanparts.com/uploa...1535658382.jpg |
The throttle position control pressure regulator, it presses onto the throttle shaft. I believe 74 and 75 had them. Mine was missing when I got the car. Search throttle control regulator.
Here's another factory explanation taken from 1973.5 CIS Thrtottle Valve valve?
See page 10 & 11 of 73 911T CIS Print for an easy to read page (PDF page 11 & 12).
73 911T CIS Print Thanks to Jims Basement Workshop |
thanks for the replies, i ll try to do a drawing of how mine is piped,, i
Replacement WUR........
Silver, Could you post a picture of the WUR (#28) installed on your engine? Better still do you have a -009 or -129? Keep us posted. Thanks. Tony |
wur
will post a picture, car is not accessible tonight
| All times are GMT -8. The time now is 12:54 PM. |
